Hi
I know this isn't currently possible, but is the ability to use Adaxes custom attributes in a Business Unit Criteria something you are looking into? It would make the business units far more powerful and usable than they currently are.
Matt
by (2.0k points)
Hello Matt,
We are constantly checking for the possibility to add the feature. Unfortunately, there is currently no way to do that.
Thanks as always for the quick response
Can you explain why? It look like the lack of actual upgrade process (instead of the current unistall / reinstall one) is the source of this failure.
Why can't we have a normal upgrade process?
It looks like you commented on the wrong question. The one above has nothing to do with the upgrade process.
Im trying to rename "Extension attribute 1 and 2" to something legible for users. Is there a way to cahnge the dsiaply name myslef like how other attributes are done?
asked Feb 17, 2023 by raul.ramirez (210 points)
Hi I'm wondering how we can use the custom attributes we can set when creating a new container in Adaxes? As an example, I would like to use one for the ... how would we go about updating the attribute once the certificate has been renewed? Thanks Matt
asked Apr 28, 2021 by chappers77 (2.0k points)
I am trying to do a bulk update of a few custom properties that I added. I read this article Custom Properties in Search & PowerShell?. But I am not able to retrieve ... able to get other AD properties using the Get, e.g, user.Get("samAccountName") works
asked Jun 20, 2013 by sdavidson (730 points)
Hello, We recently applied the 2023 upgrade following the backup / uninstall / install / restore procedure and we faced an issue: UUIDs for Business Units changed, which ... upgrade Adaxes in the future that does not delete and recreate Business Units? Cheers
asked May 4, 2023 by ygini (240 points)
When creating custom commands you have to select the object type. What is the object type for a Business Unit? It doesn't seem to be OU or Container as I can not select ... execute my script against. I've been searching the site and can not find this detail.
asked Jul 5, 2021 by ComputerHabit (790 points)
3,365 questions
545,268 users
