Dear colleagues, can you please advise if it is possible to create (and update reqularly) business unit of computer objects based on a query to external SQL DB (hostnames stored in SQL)? Thanks!
by (920 points)
by (273k points)
Hello Dmytro,
Unfortunately, there is no such possibility using business unit membership rules. However, it should work just fine using a scheduled task and a script. The script will query your SQL database and then add a dedicated membership rule for each computer to the business unit.
Thanks! Do you have by any chance an example on how to manipulate the membership rules via script?
+1
Hello Dmytro,
Sure, have a look at the following SDK article: https://adaxes.com/sdk/SampleScripts.ModifyingMembershipRules.
We would like to have a business unit that is based on an adaxes custom attribute. I don't see a way of doing this. Do you all have any ideas?
asked May 18, 2020 by mark.it.admin (2.3k points)
Is it possible to query the external SQL database for audits of a specific action, even if that action is a 'sub-command' of a business rule, scheduled task etc? Simple ... interested if data is structured in the log in a manner that would allow this? Thanks
asked Aug 30, 2014 by firegoblin (1.6k points)
I'm trying to setup SelfService group management. We have multiple Forests. Because of the Forests we can't add users from a different forest to the ManagedBy. We can add a local ... end up getting all the groups a user is a memberof or nothing at all. :)
asked Jun 23, 2021 by ComputerHabit (790 points)
Hello, I have some AD Groups I would like to exclude from a business unit I'm using. I have standard group names across multiple OUs, some should be a part of the ... than simply having a working exclude query. Any thoughts on how I can get this working?
asked Mar 24, 2016 by drew.tittle (810 points)
Hello, we manage 20 Domains with Adaxes. How can we create a Business Unit that holds all objects within OU's /Builtin and Users of all managed Domains without adding each OU seperately? regards Helmut
asked Jan 21, 2021 by a423385 (510 points)
3,371 questions
545,356 users
