I read the article on using a business rule to automatically set certain field values such as address based on the value of the Office field.
Is there any way to do this in real-time in the Web Portal? For example, if the user sets the office to a specific value it automatically populates the values of the address, Zip, etc with the correct values for that office?
The downside of the business rule method is that you either have to remove the fields from the web forms so people don't manually put values in or you need to set a default value telling them not to set the field because it will be set by a rule. This works fine in most cases but we have a case where the Office value could be "Remote" for a remote user in which case the telephone number or address might need to be set. That is a little difficult to convey with information in the fields themselves.
It would be much easier if the values of those fields auto-filled with the the correct values based on the Office field so the user has immediate feedback and can change it if necessary.
by (110 points)
by (110 points)
I take it the answer to this is a "No, it can't be done?"
You can do that on the back-end like in the Adaxes Administrative Console and just show the field after user creation process completes. Just add the additional changes for remote on execution page.
Hi all, I have a quick question regarding the web interface. Can I constrain a selection, for example Department, based on what the user will choose in the Company field? ... property patterns but wonder if I can take this one step further thank you, ice-dog
asked Mar 4, 2019 by ice-dog (170 points)
asked Jan 20, 2020 by KIT (910 points)
We have a New User action set up for our HR staff to use. There is a field in the custom form that states "Notes for IT Department". I want to display the data that is ... IT Helpdesk. I don't know what parameter this would be considered. How can I find out?
asked Feb 14, 2020 by slowllama (100 points)
Update group membership based on one property values. I am trying to find a script that resembles "Update group membership based on two property value" but just for one value.
asked Apr 7, 2022 by lee_thomas (20 points)
Hi, as the subject indicates I created a form within Adaxes using adm-CustomAttributeText to display various DropDown fields. My question is, is it possible to somehow link a ... fields to create a group and if so how should it look like? Regards Ingemar
asked Feb 13, 2014 by ijacob (960 points)
3,356 questions
7,799 comments
545,164 users
