Greetings. When I create the parameters to make a business rule that looks for users whose Email Proxy Adresses does not contain 'SMTP:%userPrincipalName%', it still generates profiles whose Email Proxy Addresses do contain 'SMTP:%userPrincipalName%'. Is this a bug or am I doing something incorrectly? I need to find profiles whose UPN and primary SMTP address don't match. Version is 2023
by (80 points)
Sorry for the confusion, but we are not sure what version of Adaxes you are using. According to the screenshot, it is 2021.1 or older, not 2023. Please, follow the steps from this help article to check your Adaxes version: https://www.adaxes.com/help/CheckServiceVersion.
It's 2023. You can still access this promprt after you toggle the "Advanced" slider and click "Edit."
Thank you for the confirmation. Unfortunately, there is no possibility to create a business unit like you need only by means of membership rules. The thing is that value references resolve into the value of the currently logged on user. As such, the unit can only contain the accounts that their primary SMTP address set to the userPrincipalName of the logged on user. To achieve the desired, you can use a scheduled task that will set a specific AD property to a certain value (e.g. set Description to mismatch) and then use the corresponding membership rule in your business unit. For example:
We have users with a value of a space for their mobile number and telephone number. I would like to figure out who these users are and null the value. Or if the value contains a number leave it alone. if it does not have a number then null the value.
asked Nov 15, 2022 by B_Witmer (40 points)
Hi, I'm trying to create a web console only for sending SMS using adaxes 2018.2. The SMS-users that are going to use the console should only be able to view users, not edit ... which removes a lot of OUs that the users should not see or be able to browse to.
asked Sep 2, 2020 by eirikza (120 points)
asked Mar 2, 2022 by Keonip (160 points)
Hello, Is it possible to grant members of a business unit permission to run a custom command? I know I'm able to give permission to a user/group to run a cmd on a business ... that can run the command. I've not been successful with any of my attempts to do so.
asked Mar 23, 2017 by JoCCCsa (100 points)
This issue affects only Adaxes versions that use the Exchange Online Management (EXO v3) PowerShell module: Adaxes 2023.2 - all versions Adaxes 2023 - starting from version 3.15. ... . For more details, see how to Register Adaxes as an app in Microsoft Azure.
asked Jun 23, 2023 by Adaxes (550 points)
3,356 questions
7,799 comments
545,170 users
