I am struggling with following task:
  • lets say I have group "license_E3"
  • before user or group is allowed to be added to this group, check whether there is enough free E3 licenses
    • if it is, add such member and assign the license
    • if it isn't, show error message
  • if member is removed from this group, remove its E3 license too
Make the solution generic so it can be scalable for several "license_XXX" groups.
I've read following articles but still I am unsure how to do this task the right way.
https://www.adaxes.com/help/AutomaticallyAssignOffice365Licenses/ https://www.adaxes.com/help/AddUsersToGroupsByDepartment/ https://www.adaxes.com/script-repository/assign-office-365-license-based-on-availability-s472.htm
Thanks in advance
by (910 points)
In case of adding a single user to a group, it is obvious that you need to check that there is at least one available license. But what should be checked when a group is added to a group?
What exactly do you mean? Do you have groups named after Microsoft 365 licenses? Pay attention, that only SKU part numbers can be used to check/assign licenses.
For your information, Microsoft 365 has a group-based licensing feature which does exactly what you described. The following article should be helpful: https://learn.microsoft.com/en-us/azure/active-directory/enterprise-users/licensing-groups-assign.
That there is enough licenses for every group member. Ideally skip disabled ones and such that already has such license (thanks to membership in other already added group etc).
I meant I want solution that will use one (or as few as possible) custom rule (or whatever) that will accept parameters aka it will be possible to use one rule for all those "licensing groups". So the maintenance of such solution will be easy and it will be easily understandable.
I am really looking for the logic how to set this up, more than the scripts. Aka create business rule, scope it to xyz, create custom command with following parameters and attach it to the business rule etc.
Yes I know, but I want have mentioned pre-checks that will warn user that there is not enough licenses aka he wont be able to add new members to "licensing group" before needed licenses will be purchased.
Thank you for all the provided details. The easiest way to configure such a workflow is as follows:
  • Enable group-based licensing in Microsoft 365.
  • Add the SKU part numbers of the corresponding Microsoft 365 licenses to an attribute of the corresponding groups. For example, you can use an Adaxes custom sttribute, CustomAttributeText1.
  • Create a business rule triggering After adding a member to a group and add the licensing groups to the Activity Scope of the rule. In the rule, there will be a script checking the license count and either do nothing or cancel the operation.
  • There will be no need to do for the removing members part as it will be automatically handled by Microsoft 365.
Hello, nice idea but there is one reason why we don't want to use Azure group-based licensing in Microsoft 365. If you try to add (using group membership) license plan with conflicting sub-license it will cause an error and the license won't be added. We want to make sure this won't happen therefore pure adaxes way is I believe better? Do you solve this kind of issues or it must be scripted. And if so, can you please provide such script that will add license plan without conflicting sub-licenses.
Thanks in advance
The license assignment can only be done using scripts. As we understand, you mean that the Microsoft 365 licenses already assigned to a user might have services that will conflict with the license being assigned by the workflow. If that is correct, that is not something you can check using scripts. The actual check is performed on the side of Microsoft 365.
Create the group-based rule, when you create the user and it is in the group the license will be added. The question is, if the group is added later to the user, will the O365 license be added? https://imgur.com/T6Qtnch
asked Jan 23, 2019 by user1928 (550 points)
Hello, is it possible to update a user attribute (extensionAttribute5) with the name of the group (Name), the user was just added to? Example: In Group A gets a new ... A should be written in the attribute extensionAttribute5 of User A. Can you please help me?
asked Jun 27, 2023 by lohnag (160 points)
Hello, I need some advice. I'd like to create a specific After user creation action, but I don't know exactly how. In our environment a new user need to assign a MS365 ... 313/create-user-mailbox-in-office-365 Will it work in 2020? Thank you for your answer.
asked Dec 14, 2020 by the7thever (50 points)
Hello, How to assign a new upgrade license? Is there a way to remove the old license? Michal
asked Apr 16, 2013 by Michalmm (40 points)
Hello all, The company I work with has recently decided to change their O365 assignment methods - from direct Attribution, to group (inherited) assignments. Since then, the ... encountered the same situation, and does anyone has a solution to share ? Thanks,
asked Jul 4, 2022 by LCouv (20 points)
7,805 comments
545,199 users
