Starting from Adaxes 2023.2, Adaxes uses the EXOv3 PowerShell module for all operations in Exchange Online. This means basic authentication in WinRM can be disabled on the computer where Adaxes service is installed.
However, earlier versions of Adaxes used PowerShell remoting to perform operations in Exchange Online. If basic authentication in WinRM was disabled, you would encounter the following error message:
Connecting to remote server outlook.office365.com failed with the following error message: The WinRM client cannot process the request. Basic authentication is currently disabled in the client configuration. Change the client configuration and try the request again.
If you see this error message, you need to enable basic authentication in WinRM. Basic authentication will not be used to send your username/password combination in plaintext over the internet. Even in versions before 2023.2, Adaxes connected to Exchange Online using modern authentication based on OAuth. Basic authentication was required to send the session's OAuth token because the client-side implementation of WinRM does not support OAuth.
by (550 points)
reshown by
asked Oct 5, 2022 by mightycabal (1.0k points)
we've migrated over to Application ID authentication...can this be updated to utilize this instead?
asked Oct 21, 2021 by jlaquatra (20 points)
asked Nov 7, 2023 by johanpr (80 points)
I am trying to view AD authentication logs to see a user account's authentication attempts. Can this be done in Adaxes?
asked Dec 30, 2021 by Tfarmer (160 points)
We have a fleet of Macbooks that use NoMAD to handle AD Authentiction and syncronization. How can we use Adaxes to handle the Password reset utility with these users. If they ... resync will be needed. Anybody else doing this or have a solution to the above?
asked May 13, 2020 by jcalvert (60 points)
3,356 questions
7,799 comments
545,164 users
