Hi, I need same functionality as is rule-base membership for AD groups, but for AAD groups.
To be more specific, I want to have AAD group that contains all user members from all selected groups (even nested ones!)
by (910 points)
Yes, it is possible. Adaxes does not have limitations on making groups rule-based. It can be on-premises and Azure AD groups. For information on how to customize the rules you need, have a look at section Rule-based groups of the following tutorial: https://www.adaxes.com/help/AddUsersToGroupsByDepartment/#dynamicgroups.
hey, what about rule-based membership for MS365 groups. It doesn't seem to be possible. The list of groups just goes blank when I try to find one in selection criteria.
As it was mentioned in the previous reply, it is possible. Any group can be made rule-based in Adaxes no matter if it is an on-premises AD group or and Azure AD one.
What exactly do you mean? Please, specify the steps you perform in all the possible details.
For Azure AD group it works. for MS365 - not. I've searched for the same security group.
Please see the screenshots. MS365 groupAAD security group
Do we understand correctly that you change membership type of group MOB.R.ms365sync.test to rule-based and attempted to add a membership rule with the very same group selected? If that is correct, the group not being available for selection is expected as it will just never work. Are you able to see/select other groups?
no, you got me wrong. I have AAD security group1 where I can add AD security group MOB.R.ms365sync.test via the rule-based condition. I also have Microsoft 365 cloud group2 where I can't add AD security group MOB.R.ms365sync.test (or any other group in this regard) via the rule-based condition. No groups are available for searching
Thank you for the confirmation. For troubleshooting purposes, please, specify the following:
  • Are the screenshots taken while logged in to the same Web interface?
  • Were you logged in with the credentials of the same user account?
  • What version of Adaxes are you using? For information on how to check that, have a look at the following help article: https://www.adaxes.com/help/CheckServiceVersion.
  • yes
  • yes
  • 3.15.20916.0 (64 bit)
Might it be related to an Azure registered app permissions? It doesn't have Global Admin role, Directory reader + Exchange admin + User admin instead.
Thank you for the provided details. Please, try logging in to the Web interface with the credentials of the Adaxes service account. Does the issue persist then? What about other Web interfaces? Is the behaviour the same?
Also, please, send us (support@adaxes.com) a copy of the Adaxes Event Log in EVTX format. For information on how to view the log, have a look at the following help article: https://www.adaxes.com/help/ServiceEventLog.
A little bit of context: There are 3 departments that share 1 Active Directory. Now each department has its own OU. I would like to have an email sent when a user is ... if this is possible without Powershell? If not, is there a pre-existing script for this?
asked Oct 3, 2023 by Cas (150 points)
Hello! Is it possible to have 2 instances of Adaxes on separate servers without sharing configuration under 1 license, if total amount of users is below the license limitation? Thank you, Dmytro
asked May 25, 2023 by Dmytro.Rudyi (920 points)
We are migrating away from on-premises AD toward cloud-only. Currently we are in a hybrid configuration with both on-premises AD and Azure AD. We are preparing to eliminate on-premise ... run Adaxes on a Azure vm server with only Azure AD an no on-premise AD.
asked Oct 6, 2023 by kevinleaverton (20 points)
3,365 questions
545,264 users
