This is more a general question to the community not a support request - What tools or products have you integrated into your Adaxes workflows?
One example that I did was make a script to connect to our local SCCM server to obtain a user's primary computer name and see if it's reachable or not.
Another example I'm working on is integrating our ITSM: ServiceNow to kickstart user account creations by calling a custom command to pass user properties to Adaxes.
What are your ideas? :)
by (270 points)
Adaxes allows you to send requests to third-party software and vice versa using scripts. For requests to ServiceNow, you can check the following documentation: https://docs.servicenow.com/en-US/bundle/tokyo-application-development/page/integrate/web-services/reference/r_AvailableWebServices.html.
We want to automate the provisioning of skype users with adaxes. Therefore we installed the Skype module onto the adaxer server. Then we tried to utilise some commands in a ... . How can the Skype module be integrated for Adaxes? Thank you for your help.
asked Apr 23, 2020 by PGstoehl (100 points)
Hello, Do you have some references of customers using MIM or other products as identity's source ?
Hi , I would like to know that is there any API service, where we can work on objects inside Adaxes tool? Preferbly REST API?
asked Nov 6, 2019 by Anil (20 points)
I would like to replace some characters "before user creation". With character like umlaute "ä", "ö", "ü". The script works. But characters like "é", "ô" doesn't seem to ... upn we have some issues with it in the Azure World. Do you have a solution for this?
asked Jun 20, 2023 by VinAx (50 points)
3,365 questions
545,274 users
