We are trying to create a custom command to create a new network share folder and offline PST file for new users. Do you have any documentation to start our process with>
by (3.2k points)
Could you specify, what you mean by offline PST file exactly?
Our users currently get an PST file hosted on the network where they can place the old emails they need to hold onto. Creating the network share is the more important part as we may be switching to a better email solution soon.
Hello Adaxes Support, I'm using this Skript for creating a Userfolder on a Server including ACLs. It works fine. $strPath="\\%adm-CustomAttributeText16%\d$\Benutzer\%username%" $Username ... this Folder but I'm not able. Can someone help me? Thanks in advance
asked Jul 31, 2013 by Napoleon (700 points)
An environment that we wish to use Adaxes on is completely isolated with no access to the internet. Things can be downloaded from the internet and then moved ... offline environment? Can Adaxes be patched and upgraded in an offline environment? Many Thanks
asked Apr 13, 2020 by antondubek (440 points)
3,362 questions
7,812 comments
545,225 users
