I am attempting to configure a business rule that adjusts an adaxes custom property of a user, upon that user being added/removed from a group. I cannot seem to find the right way to go about this. I have tried setting it up from the group perspective, and using the %adm-memberUserName% to pull the user and my target custom variable I wish to change is %adm-CustomAttributeBoolean20%, but I cannot get anything to interact with or change this variable. I am not sure how to reference a custom variable properly when trying to adjust it based on my criteria above. Can support/anyone help me? What is the proper way to reference custom values so I may manipulate them when scripting in powershell? I apologize if this is in your FAQs or Documentation, I cannot find it. There is plenty on referencing normal values, (like username, office, description, email, etc.) but not so much on custom attributes.
by (70 points)
Value references work the same for all types of objects and properties. The following article should be helpful: https://www.adaxes.com/help/ValueReferences. At the same time, you need to pay attention what the target object is. In your case, it is a group, not the member being added. The behavior is by design and comes from AD. The thing is that when you add/remove a member from a group, it is the group being updated, not the member. As such, if you need to update a property of a member being added to a group in your business rule, you should have a script like below. In the script:
  • $propertyToUpdate - Specifies the name of the property to update for the member.
  • $propertyValue - Specifies the value to be set for the member property.
$propertyToUpdate = "adm-CustomAttributeBoolean20" # TODO: modify me
$propertyValue = $True # TODO: modify me
# Bind to the member
# Update member
$member.Put($propertyToUpdate, $propertyValue)
$member.SetInfo()
asked Aug 27, 2019 by ngb (220 points)
asked Oct 18, 2022 by lw.fa (130 points)
I have a Business Rule that is suppose to remove a User from a Universal Distribution Group based on a DN Group Template string ("CN=%division% List,%adm-ParentDN%") but despite it ... , it is correct and the group exists. I don't know what else to check.
asked Jun 4, 2019 by Staj (350 points)
I have a Rule-Based group with users. Every time a users gets added or removed from this group I want to trigger a Business Rule for "Atter adding or removing a member ... Rules be triggered by a Rule-Based group adding or removing a user? Morten A. Steien
asked Mar 27, 2023 by Morten A. Steien (300 points)
3,365 questions
545,274 users
