What is the minimum permission required to move user accounts between OUs?
by (950 points)
The user must have the following permissions:
  • delete AD objects from the source OU,
  • create new objects in the destination OU,
  • have the Write permission for the Name and CN (Full Name) properties of the source object.
In the next version the last permission will not be required if the object name is not changed during the operation.
Adaxes 2012.1 introduces two new permissions for Security Roles:
  • Move Objects from - allows users to move AD objects from a given OU.
  • Move Objects to - allows users to move AD objects to a given OU.
With the help of the new permissions, you can allow users to perform the Move operation without giving them rights to delete and create objects.
I have a root OU that I created called Disabled. I want to give the Computer Manager role the necessary permissions to move a computer to any OU/sub tree desired. They can ... -in computer OU but nothing else. What Permissions do I need to give them? Thanks!
asked Apr 30, 2012 by mpaul (360 points)
Hello all, I'm sure this is possible, but I'm confused on a few points. I'm trying to set up the security role and matching homepage action that will allow a user ... I'd like to use the least amount of permissions possible, just for security's sake. Thanks!
asked Jan 18, 2017 by ctdhelpdesk (190 points)
What permissions does a Trustee (Specifically a Manager or Owner) need over a Managed Object to make it visible in their My managed objects? The Trustee can view their ... missing read permissions of specific attributes, which are the minimum I need to allow?
asked Nov 2, 2023 by Viajaz (210 points)
What permissions are required in Exchange Online to use the "Cancel meetings organized by the user"?
asked Jun 5, 2023 by william.malone (60 points)
3,365 questions
545,245 users
