we are running Adaxes in hybrid setup and on-prem as O365 is connected.
Based on articles I have read here, the local mailbox should be moved and converted into remote mailbox automatically, if a license is assigned, no?
However, the mailbox stays local only with a mailbox size of 2GB.
Onprem: image.png
Online: image.png image.png
Anything I am missing or misunderstood?
by (1.1k points)
You don’t need to create a mailbox in an on-premises Exchange using the Create Exchange mailbox action and you don’t need to migrate the mailbox. You just need to assign a Microsoft 365 license with access to Exchange Online. Exchange Online will provision the cloud mailbox while Adaxes will automatically enable a remote mailbox. Your business rule should look something like this: image.png
I see, and changed rule as you showed it.
Hello, We are using adaxes with a M365 hybrid environment and right now we have to manually create a remote mailbox on prem after user creation. ... -Identity "user@mydomain.com" -ExternalEmailAddress "user@mydomain.onmicrosoft.com" Enable-RemoteMailbox "user"
asked Oct 16, 2020 by copatterson (70 points)
Howdy - Has anyone run into this message before? The changes never make their way through, I just have to manually do them. WIll I just need to create custom powershell scripts to achieve these items?
asked Feb 27 by ajblevins (20 points)
asked Aug 1, 2023 by curtisa (210 points)
I'm testing making changes to a mailbox that is synced between AD and Office365. During changes updates are not reflected back. I'm prompted that the replication with AD Connect has ... in the web interface. If I go to the console I can see the change.
asked Aug 6, 2020 by ComputerHabit (790 points)
3,355 questions
7,799 comments
545,152 users
