I'm using the default builtin password expiration notifier.
I have it set to run everyday at 8AM, to check if the password will expire in <7 days, and send an email out to the user.
SMTP settings are verified, test successfully run when sent.
Scope is a singular domain in my enviornment.
Adaxes Version: 3.16.21627.0
I came back to the adaxes console this morning (after the weekend) and saw the task had been running for nearly 24 hours, no completion.
What is happening here?
by (60 points)
For troubleshooting purposes, please, provide the following details:
  • A screenshot of the scheduled task configuration including the Activity Scope section.
  • Specify how exactly you see that the task runs for over 24 hours.
  • Send us (support@adaxes.com) a copy of the Adaxes Event Log in EVTX format. For information on how to view the log, have a look at the following help article: https://www.adaxes.com/help/ServiceEventLog.
You can see by the screenshot that it's currently running for 20 hours now.
Thank you for the provided details. The event log is filled with errors related to on-premises Exchange. Most probably, your Exchange servers were not decommissioned correctly. If you are not actually using on-premises Exchange, restrict Adaxes from connecting to any of them: https://www.adaxes.com/help/AllowedExchangeForestsServers. Once done, check whether the issue persists.
Thank you! Will get working on this.
I've enabled the "Account Expiration Notifier" builtin scheduled tasks. Currently, I'm testing it so I have "If account will expire in less than 300 days", it will send an ... SMTP settings are correct, seeing as I get the test send. What's going on here?
asked Jan 4, 2021 by keecit (60 points)
Is it possible to setup a scheduled task for password expiration notifier to send one email a day for accounts whose password will expire in less than X amount of days that have ... expiring on the same day. There will be a lot of emails going at once.
We are using the Builtin scheduled task to let our domain users know when their password will expire in the next 2 weeks. As in ... If password will expire in less than ... problem (like wjpatterson, above) the Password section has a N/A in it. Regards, Jim
asked May 13, 2014 by jfarley (20 points)
Right now I have a scheduled task that runs on all user accounts and sends and HTML email to users when their password will expire. The problem with this method is that ... to look for users with expiring passwords. I could use some help sorting that out.
asked Jul 10, 2020 by dtb147 (290 points)
I want to send reminder emails that a users password is going to expire when their password is going to expire in 14, 7, 3, and 1 days. I have setup 4 ... a daily PowerShell script, where I do the actual password expiration check in the PowerShell script?
asked Aug 9, 2017 by HDClown (220 points)
3,351 questions
545,093 users
