Hi if a request is send to the supervisor of the requester and he does not approve in 7 days can the request be forwarded to the supervisors manager for approval?
by (100 points)
by (273k points)
Unfortunately, there is no possibility to forward approval requests. However, you can add new approvers. The following script from our repository will be helpful: https://www.adaxes.com/script-repository/add-approvers-to-approval-requests-s124.htm. If you face issues updating the script to meet your needs, we will gladly help you.
Hello, Based on your script, we check whether there is already a request. However, we often get the following error and do not know why. Can you help us? ... Cannot compare "Softerra.Adaxes.Adsi.Search.AdmSearchResult" because it is not IComparable. Thank you
asked Apr 16 by DRiVSSi (280 points)
I have reviewed the the actual logs under logging and can see tasks that went off for approval, but when I select Approval Requests - I cannot find them under approved, ... I select All - Approved it shows me 1000 and that never grows beyond that number.
asked Dec 21, 2012 by mpaul (360 points)
Hi, I am trying to set forwarding for a shared mailbox to a contact. Adaxes is not able to find any contact? I tried to search by name and then selected OU itself, but no objects found. Best Christian
asked Nov 27, 2023 by wintec01 (1.1k points)
Hi Are there any plans to allow the creation of approval requests via PowerShell? My client has a requirement to allow staff to request new Teams, but the Team needs to ... could be a balance of both automated approval emails and not as required. Thanks Matt
asked Oct 12, 2023 by chappers77 (2.0k points)
3,372 questions
545,359 users
