Hi
Is it possible to get the Web Interface address via a script?
Matt
by (2.0k points)
Hello Matt,
Yes, it can be done using value reference %adm-WebInterfaceUrl%.
Argh, the one place I hadn't looked. I was trying to find it through GetConfigurationContainerPath.
Thank you as always.
Hi We have Adaxes available through Azure app proxy as we have external support for some of our companies and these people don't have VPN available to them. The ... change the Web Interface Address to the Azure link? Will this break anything? Thanks Matt
asked Jan 20, 2022 by chappers77 (2.0k points)
I am evaluating Adaxes. I noticed that the web interface does not allow modification of the External Email Address (ms-Exch-Target-Address). What would someone do if they needed to change the Target Address?
asked Aug 6, 2020 by ComputerHabit (790 points)
Hi I've created a new adaxes configuration and limited access to do things based on the 'actions' section: only create, modify, delete contacts are available. Added myself to ... since updating to version 3.16.21408.0. How can I resolve this error? Thanks
asked Oct 4, 2023 by cheezoid (20 points)
Hello, I want to give the ability for the Help Desk to add a new IE trusted site. I did a Custom Commands that works well. $scriptBlock = Powershell { Import-Module Adaxes Import ... ( $Zone). The GPO name ($GPOName)will never change. It is possible to do it?
asked May 31, 2016 by tentaal (1.1k points)
7,806 comments
545,206 users
