Is it possible using PowerShell to copy group memberships from an already existing user without copying 2 specific groups named for example test and test 1 ?
We are currently already using a PowerShell script to copy the group memberships, so only the part that needs to be added in which 2 certain groups are not included.
I can share the PowerShell script if needed.
KR, Cas
by (150 points)
Hello Cas,
Have a look at the scripts from the following article in our repository: https://www.adaxes.com/script-repository/copy-group-membership-from-specified-user-s590.htm.
Thanks for your quick reply!
Is it also possible to do this based on, for example, the first 4 characters of the groupname, where the rest of the name is variable?
Example:
SEC-"variable" or APP-"Variable". So that it skips everything with "SEC" or "APP" in the groupname ?
Hello Cas,
The functionality is already present in the first script from the article we referenced. In your case, you need to set the $groupNamesToSkip variable as follows:
$groupNamesToSkip = @("SEC*", "APP*") # TODO: modify me
Thanks for your answer. I have it working now!
KR, Cas
asked Apr 21, 2020 by RayBilyk (230 points)
Hi, Group memberships are kept when using "User Copy" function. Is it possible to do the same thing between two existing users ? (custom commands or else) Thanks for your response, Yoann
asked Oct 4, 2012 by yoann.hamon (180 points)
How can I create a script that does these things For internal audit. objective Even removing all groups of a disconnected user, we will still know which groups the ... in the created group (audit)-sAMAccountName-access add the (user)-sAMAccountName in members
asked Jul 2, 2022 by alancardoso (40 points)
I've looked at https://www.adaxes.com/script-repository/copy-group-membership-from-specified-user-s590.htm. is there away to change from group names to a group type? Like exclude all distribution groups?
asked Dec 4, 2023 by Derek.Axe (480 points)
Hello Back when we first started using Adaxes you created a couple of great scripts which worked together really well, the first one copied one users group membership and put in ... an addition to what groups the second user is already a member of? Thank you.
asked Aug 4, 2015 by CBurn (700 points)
3,354 questions
7,798 comments
545,149 users
