We have several Office 365 groups where the someone is an Owner but not a Member, and we'd like to give them the ability through the web interface to give them the ability to add/remove members of those groups in the same way they could do it for internally hosted distribution groups.
Is there a way to create an option in the web interface to allow them to add or remove users via a custom task?
Hello Paul,
Unfortunately, there is no such possibility as currently only on-premises AD users can log in into Adaxes. The feature will be available in future releases.
We get the following error when attempting to edit a room or equipment mailbox in the web interface. We can edit them using the admin console. I am a full Adaxes Admin so I don't think permissions. I also don't see an error in the logs.
asked Dec 9, 2020 by mark.it.admin (2.3k points)
I'd like to implement an architecture whereby all Domain Users can request membership in any domain security group. I'd also like to allow the OU Owners to have ... from their groups without granting them the ability to remove users from all security groups?
asked Mar 25, 2020 by sirslimjim (480 points)
Ver 2014.1 I'm working with a large amount of users and would like to change these properties in bulk: "User must change password at next login" "Password never expires" I cannot find a way to do this in the web console. Is this possible?
asked Sep 22, 2014 by jstinson83 (130 points)
Is it possible to provision Lync access to users through group membership? For example, let's say we don't want to provide Lync to all users so we have a security group ... when they are added to that group and disable it if they are removed from the group?
asked Feb 13, 2014 by RickWaukCo (320 points)
7,806 comments
545,208 users
