Ever since upgrading to 3.16.21906.0 the script here no longer works: https://www.adaxes.com/script-repository/move-mailbox-tofrom-microsoft-365-s579.htm
Not sure what the issue is as I can't find any errors in the log.
by (210 points)
What exactly do you mean by no longer works? Do you face any errors/warnings? If so, please, provide screenshots. Also, please, follow steps 1-4 from this article and provide us with a screenshot.
You can post the screenshots here or send to us at support@adaxes.com. Any additional details will be much appreciated.
I was noticing similar behavior in our environment and wanted to share what we found. I was attempting to use the same script to move a Shared mailbox from OnPremise to ExO M365. I enabled Exchange tracing in Adaxes. Running Adaxes 2023.2 version 3.16.21906.0 as well.
[01/10/2024 10:28:48] New-MoveRequest -Identity "3478596c-bb45-484f-9a47-e341dd6c88f8" -Remote "True" -RemoteHostName "XXXX.XXXX.com" -TargetDeliveryDomain "XXXXX.mail.onmicrosoft.com" [01/10/2024 10:28:59] System.Management.Automation.ParameterBindingException: Parameter set cannot be resolved using the specified named parameters. at System.Management.Automation.Runspaces.PipelineBase.Invoke(IEnumerable input) at System.Management.Automation.PowerShell.Worker.ConstructPipelineAndDoWork(Runspace rs, Boolean performSyncInvoke) at System.Management.Automation.PowerShell.Worker.CreateRunspaceIfNeededAndDoWork(Runspace rsToUse, Boolean isSync) at System.Management.Automation.PowerShell.CoreInvokeHelper[TInput,TOutput](PSDataCollection1 input, PSDataCollection1 output, PSInvocationSettings settings) at System.Management.Automation.PowerShell.CoreInvoke[TInput,TOutput](PSDataCollection1 input, PSDataCollection1 output, PSInvocationSettings settings) at System.Management.Automation.PowerShell.Invoke(IEnumerable input, PSInvocationSettings settings) at #Dh.#Jh.#l.#5w.#VZc(RunspacePool runspacePool, PSCommand psCommand, String[]& warnings) at #Dh.#Jh.#l.#5w.Execute(#Gh command) at #Dh.#Fsf.Execute(#Gh command) at #ik.#hXe.Execute(#Gh command)
When I ran the new-moverequest command by itself on our on-premise Exchange 2016 server the error became more clear.
[PS] C:\Windows\system32>New-MoveRequest -Identity "3478596c-bb45-484f-9a47-e341dd6c88f8" -Remote "True" -RemoteHostName "XXXX.XXXX.com" -TargetDeliveryDomain "XXXX.mail.onmicrosoft.com" A positional parameter cannot be found that accepts argument 'True'.
  • CategoryInfo : InvalidArgument: (:) [New-MoveRequest], ParameterBindingException
  • FullyQualifiedErrorId : PositionalParameterNotFound,New-MoveRequest
  • PSComputerName : XXXX-exch04.XXXX.com
So it appears the -Remote "true" is the extra positional parameter it did not like. If you remove "true" and just leave -Remote you get positive results, and the command gets farther.
I am still having issues on my end with the move requests because the GUID is not being found, and if i change it to the shared mailbox samAccountname it gets farther but then fails with
Target user 'sharedMailboxName' already has a primary mailbox.
That part may be entirely on my end. But I think the Remote part is what is causing the issue I saw and CurtisA saw as well.
What you see in the tracing is not an issue and is not the actual command sent to exchange. It is just the way it has to be and works fine as per our check.
For troubelshooting purposes, please, follow steps 1-4 from this article and provide us with a screenshot. You can post the screenshot here or send to us at support@adaxes.com.
asked Aug 1, 2023 by curtisa (210 points)
Good Afternoon, Is it possible to move mailboxes to 365 using more advanced options? I am already using the documented script but we have a need to use other switches in the ... this. I see the native way only supports a couple of options that are documented.
asked Nov 22, 2023 by curtisa (210 points)
Hi I'm trying to add your report from here but whenever I run it, I get 2 errors for each user which seem to correspond to the following 2 lines in the ... "user" $Context.DirectorySearcher.AddCriteria($criteria) But I still get the same error's. Thanks Matt
asked Oct 16, 2023 by chappers77 (2.0k points)
The built in functionality to convert exchange online mailboxes to shared does not work for users that are synced from our local AD via Azure AD connect. How can we over ... account to in cloud from synced with AD all our issues with this would be resolved.
asked Jul 31, 2019 by john.morrow (270 points)
7,805 comments
545,177 users
