I am running the web interface on a separate server from the Adaxes Service and all 3 directories (admin, helpdesk, selfservice) are currently install in a single IIS site.
I want to split these up into 3 different IIS websites, so that I can have different URL's and make selfservice externally accessible outside the firewall, but not admin and helpdesk.
If I do this, would I break any functionality?
What kind of issues would I run into when I need to run an upgrade on the server running the web interface and these three different websites?
In the Adaxes Service properties, there is a Web Interface tab where you can set the web interface address and a path template. The note indicates that this info is used for web links in email notifications. For all of the various email notifications that would pull from these fields, are the email templates ones I can customize, and thus hardcode web links so they reference the correct URL's, given that I am intending to split the web interface across multiple websites?
by (220 points)
by (273k points)
No.
There should be no issues.
No, the link can lead only to one Web Interface that should be accessible for all users. We have this feature in our TODO list.
As I am going to use a dedicated website for SelfService, I don't need it to be referenced by a subdirectory (virtual directory) like the installer sets up. I tried to leave the virtual directory blank during install but it would not take it.
I set the physical path in the IIS site to the place the SelfService application points (C:\Program Files\Softerra\Adaxes 3\Web Interface\SelfService) and removed the SelfService application entry on the site.
Everything is working as far as I can see so far. Any issues with continuing with things this way?
We are in the process of upgrading from Adaxes 2014.1 to Adaxes 2018.2. In our current architecture we have the web interfaces deployed to their own websites in IIS. ... like to set distinct URLs for each web interface. Thanks in advance for any assistance.
asked Feb 11, 2019 by lgibbens (320 points)
Dear Support, hope you are well during this pandemic! Can you please if it's possible to use different urls for different interfaces and how it can be set up? E.g. I ... : adaxes-L1. com for Team1 interface adaxes-L2. com for Team2 interface Thanks for help!
asked Mar 30, 2020 by Dmytro.Rudyi (920 points)
In Web administration I created Action for editing mail enabled group, but default service account doesn have rights to modify exchange. Is it possible to just this one Action pick another account? As it is possible in Custom Command?
asked Nov 21, 2019 by KIT (910 points)
asked 4 days ago by tromanko (260 points)
545,383 users
