I’m looking for a way to take a unique number from Adaxes and use part of it to create an employee ID for the AD attribute field.
by (140 points)
It can be easily done using a business rule (e.g. triggering Before creating a user) and a script. The following tutorial should be helpful: https://www.adaxes.com/help/ValidateModifyUserInputWithScript. Additionally, you can check our script repository for similar scripts, for example: https://www.adaxes.com/script-repository/generate-sequential-property-values-s494.htm.
How do I check the last number used?
I have a scheduled task that generates several reports and saves them in the filesystem. The task runs only once a day. Is it possible to trigger the scheduled task ... solution to save a report in the filesystem after user creation? Thanks for your help
asked Apr 18 by lohnag (160 points)
Hello I am trying to set up a script to copy the 'Members Of' from specific accounts to a new user account after creating the user. Something very similar to this: https:/ ... to the ever changing nature of the business. Is someone able to help me with this?
asked May 28, 2020 by adantona (40 points)
3,356 questions
7,799 comments
545,171 users
