I need to add many check-box list items to a Custom Command, I think the best way to do this is via PowerShell rather than through the UI.
What's the best way of doing this? I tried modifying the Items on the AdmCustomCommandParameterCheckList of the Adaxes Customer Command (AdmContainerPipelined) in question but it won't let me modify it. I could use reflection, or other tricks, but I think I'm probably doing this the wrong way.
# Connect to the Adaxes service.
$ns = New-Object "Softerra.Adaxes.Adsi.AdmNamespace"
# Bind to the custom commands container.
$containerPath = $service.Backend.GetConfigurationContainerPath( "CustomCommands")
$container = $service.OpenObject($containerPath, $null, $null, 0)
# Get command
$command = $container | Where-Object { $_.CommandName -eq 'My Custom Command' } | Select-Object -First 1
for($parameterIndex=0; $parameterIndex -lt $command.Parameters.Count; $parameterIndex++) {
    if($command.Parameters[$parameterIndex] -is [Softerra.Adaxes.Parameters.AdmParameterCheckList]) {
        break;
if($parameterIndex -ge $command.Parameters.Count) {
    throw "Didn't find Parameter"
# Example Items
$Items = @{
    "1" = "One"
    "2" = "Two"
    "3" = "Three"
$ItemsList = @()
foreach($Key in $Items.Keys) {
    Write-Host $Key
    $Item = [Softerra.Adaxes.Parameters.AdmParameterCheck]::new()
    $Item.ValueWhenChecked = $Key
    $Item.Name = "param-{$((New-Guid).ToString().ToUpper())}"
    $Item.DisplayName = $Items[$Key]
    $ItemsList += [Softerra.Adaxes.Interop.Adsi.Parameters.IAdmParameterCheck]$Item
    #$command.Parameters[$parameterIndex].Items.Add($Item) # fixed length array, won't work
$command.Parameters[$parameterIndex].Items = [Softerra.Adaxes.Interop.Adsi.Parameters.IAdmParameterCheck[]]$ItemsList # Also doesn't work
$command.SetInfo()
by (210 points)
Going via UI is definitely much easier. However, if you prefer using scripts, the following SDK article should be helpful: https://www.adaxes.com/sdk/IAdmParameterCheckList. Pay attention that each item has a setting for value when checked and when unchecked. If you still face issues writing the script, please, describe the desired behavior in all the possible details with live examples.
But how do I save the created instance to an existing parameter on the command?
Have a look at section Adding parameters to a custom command of the following SDK article: https://www.adaxes.com/sdk/ManagingCustomCommands/#adding-parameters-to-a-custom-command.
Is it possible to populate Custom Command Drop-Down List and Checkbox List items using PowerShell? If not, is such a feature on the Adaxes roadmap?
asked Dec 12, 2022 by Viajaz (210 points)
asked Mar 23, 2023 by mightycabal (1.0k points)
I would like to add a parameter for country to a custom command. Since the country has to be entered correctly in order for Active Directory to accept it, I would like to ... ? I didn't find it in the documentation and the sample scripts didn't use parameters.
asked Jun 4, 2020 by mark.it.admin (2.3k points)
Hello, I'm trying to execute a custom command through a Powershell script, but I'm struggling to pass multiple values to an AD Object Picker parameter. ... , $NULL, $NULL, 0) $obj.ExecuteCustomCommand($command.CommandID, $commandArguments) Thanks in advance!
asked Nov 24, 2021 by KelseaIT (320 points)
3,357 questions
7,801 comments
545,173 users
