Hey Supportteam,
are you thinking about for the next major release to implement AND and OR Selection for IF Actions?
The actual version is only supporting AND or OR selction and not both.
f.E.
Select User who are not deactivated
AND in a special group OR in a special OU.
Hope could explain my question.
Regards
Massimo
by (450 points)
Hello Massimo,
We have this feature in our Product Backlog. We will add a +1 on your part, if you don't mind.
I would also like to see this fast tracked, i am running into an issue that would be solved with this exactly right now.
Hello Massimo,
We have no exact dates of the next release that will include the feature. For now you can use the If PowerShell script returns true condition to achieve what you need.
Below is an example of the script you can use in the condition:
$ouDN = "OU=Users,DC=domain,DC=com" # TODO: modify me
$groupDN = "CN=MyGroup,OU=Groups,DC=domain,DC=com" # TODO: modify me
# Check user location
$userDN = New-Object "Softerra.Adaxes.Ldap.DN" "%distinguishedName%"
if($userDN.IsDescendantOf($ouDN))
# Check group membership
$userGroupGuids = New-Object "System.Collections.Generic.HashSet[System.Guid]"
    $Context.TargetObject.GetEx("adm-MemberOfGuid") | %%{[void]$userGroupGuids.Add([Guid]$_)}
$groupGuid = [Guid]$group.Get("ObjectGuid")
$Context.ConditionIsMet = $userGroupGuids.Contains($groupGuid)
Thank you for your replay, it would be nice to have it in the console of adaxes ;)
I would like to replace some characters "before user creation". With character like umlaute "ä", "ö", "ü". The script works. But characters like "é", "ô" doesn't seem to ... upn we have some issues with it in the Azure World. Do you have a solution for this?
asked Jun 20, 2023 by VinAx (50 points)
asked Oct 24, 2022 by mightycabal (1.0k points)
asked Sep 20, 2022 by DA-symplr (80 points)
On scheduled tasks, business rules, and custom commands, inside an if statement, you have the option for it to be "AND" or "OR" in the condition. Can there be a ... a bunch of computer accounts to be deleted. We think this would be a good safety measure.
asked Mar 22, 2021 by mark.it.admin (2.3k points)
Hi, is it possible to combine conditions with AND and OR in one action? For example: if the Operation succeeded AND the 'Department' property equals 'Marketing' OR the 'CustomAttributeText1' equals 'Yes' then Action thank you in advance, Napoleon
asked Jul 4, 2013 by Napoleon (700 points)
3,356 questions
7,799 comments
545,164 users
