In our environment, we have many business rules with "Add to group". Now I have to delete the "Add to group xyz" in all business rules, as the group is now rule-based. Is there a command I can execute in Adaxes so that I don't have to search for and delete all "Add to group xyz"?
by (280 points)
Unfortunately, there is no such built-in functionality. It might be done using a script, but we still recommend removing all the actions manually so that you are sure that only the required actions are removed.
Hello, We have some Create Business Rules with ifs and other actions. Now these have to be controlled by a third person who has no rights to the console. How can I export the ... to a .txt file? The TXT must contain the condition and the actions. Thanks a lot
asked Aug 10, 2023 by DRiVSSi (280 points)
How can I create a script that does these things For internal audit. objective Even removing all groups of a disconnected user, we will still know which groups the ... in the created group (audit)-sAMAccountName-access add the (user)-sAMAccountName in members
asked Jul 2, 2022 by alancardoso (40 points)
3,356 questions
7,799 comments
545,164 users
