What I'm trying to accomplish: user should have access to modify certain accounts where customTextAttribute2="test" (example). When I modify the criteria under "object selection" > ldap filter > i tried doing %adm-customattributetext2%=test. No results found. Is it possible to query custom attributes or do you have to use AD attributes for this?
by (180 points)
Unfortunately, there is no possibility to use Adaxes custom attributes in search queries.
Hi, I recently upgraded Adaxes from 2021.1 to 2023.2, and after the upgrade, an LDAP filter for retrieving the groups a user is owner of, stopped working. The reason ... attribute instead, like this: It works, but sadly it is quite slow. Best regards Martin
asked Aug 21, 2023 by Martin (100 points)
I'm trying to create a new command that can apply to User objects across multiple domains that are in OUs with the same 'Name' i.e. an OU called Directors that occurs in ... t seem to make it work with just contains 'OU Name' i.e. (distinguishedname=OU Name)
asked Jan 21, 2020 by richarddewis (260 points)
Hello, I have an LDAP filter on a home page action : (& (objectClass = organizationalUnit) (name = * Users)) But nothing appears When I do the search from the console with my filter, it works: the OU Users * did not directly at the domain root
asked Dec 14, 2011 by mmichard (360 points)
I've created an interface to edit adm-CustomAttributeText19 when it's empty. I set in the configuration page this filter "Only allow selection of AD objects that match the LDAP ... I open the interface, even if the field is filled. What am I doing wrong?
asked Jan 30, 2023 by Simone.Vailati (430 points)
I'd like to enter an LDAP string in the Target Object selection to allow managers in Self Service to search for staff in a variety of OU's I've tried to use the string where ... a top level OU. An answer to both types of query or either would be great. Thanks
asked Apr 25, 2018 by AlanWJ (150 points)
3,351 questions
545,083 users
