Hello
The "Send mail"-Function is not working if i use the %mail%-Parameter.
If i want to send an information like "Your password will expire in 7 Days" via mail but it wont work because the %mail%-Parameter is specified.
But if i put a specified recipient in the "To"-Field the recipient will get the message.
by (110 points)
Please, describe the desired behavior and the configuration you have in all the possible details with live examples and screenshots. You can post screenshots here or send to us at support@adaxes.com.
Send Mail with integrated mail sending function isn´t working anymore with SSL after Upgrade to 2023.2. The error code is "Send Mail with integrated mail sending function isn´t ... is working if SSL is not enabled. Does someone else have the same problem?
asked Sep 11, 2023 by robin.christmann (160 points)
Hi I'm trying to add your report from here but whenever I run it, I get 2 errors for each user which seem to correspond to the following 2 lines in the ... "user" $Context.DirectorySearcher.AddCriteria($criteria) But I still get the same error's. Thanks Matt
asked Oct 16, 2023 by chappers77 (2.0k points)
Hello, I need some advice. I'd like to create a specific After user creation action, but I don't know exactly how. In our environment a new user need to assign a MS365 ... 313/create-user-mailbox-in-office-365 Will it work in 2020? Thank you for your answer.
asked Dec 14, 2020 by the7thever (50 points)
3,371 questions
545,356 users
