I recall reading in documentation that business rules will be triggered also if changes are made in AD MMC or powershell.
Right now the rules are triggered when changes are made in webinterface and in the AD part of the administration interface but not when a change is made outside of Adaxes but directly in AD.
Would this be by design? If so would there be any way to have business rules triggered in these cases?
by (240 points)
This behavior is by design. There is no possibility to trigger a Business Rule on changes made outside of Adaxes.
Not the answer I was hoping for but thanks for the quick response.
Guess I will have to make sure all changes are done through the web interface.
Hi, I have a question about Business Rule. Can it be triggered by the operation performed outside the Adaxes system (e.g. using ADUC)?
asked Aug 5, 2011 by minhe (60 points)
Hi Adaxes Team I have created a business rule which sends a mail to our helpdesk staff after a user sets a new pw with the self password reset function. The user should ... . If this is not possible yet, please forward it as a suggestion :) regards pudong
asked Feb 4, 2022 by pudong (670 points)
Our business has tools that require tweaks when a password is changed. We want to reminder our users to make the tweaks when they change their password. Our users ... way to have Adaxes detect the password change and email the user the reminder message?
asked Mar 30, 2016 by jakesomething (190 points)
Is it possible to send an email from Adaxes when certain AD objects are modified outside of Adaxes? With Business Rules it looks pretty easy to do that inside of Adaxes ... something changes on the object and the change was not initiated by Adaxes. Thank you.
asked Jul 23, 2021 by mikek (80 points)
Every time when I try to save a change for a business rule in Adaxes Console, I got the error "An error occurred while saving the custom command. Requested Service not found" I close and open the console again but doesn't help.
asked Aug 9, 2021 by kfung00 (20 points)
7,805 comments
545,193 users
