Is there a way to auto-populate AD group membership without specifying a separate condition statement for each group? I was hoping to pass the 'department' value by reference after the user is created and then have the membership assigned to the referenced group accordingly.
by (90 points)
Yes it is possible using a script. Here is a sample one:
Import-Module Adaxes
# Bind to a group. The distinguished name of the group depends on the Department property of the user.
$myGroup = Get-AdmGroup "CN=%department%,CN=Users,DC=company,DC=com"
# Add the user to the group
Add-AdmGroupMember $myGroup "%distinguishedName%"
To use the script, you need to install the Adaxes PowerShell Module on the computer, where the Adaxes service is running. Adaxes PowerShell Module is installed with the same installation package as used to install Adaxes service.
For more details, please see Automatically Change Group Membership Using Scripts.
Hello Joe,
Probably, the issue is that the conditions of your Business Rule are not met. Can you also post the actions and conditions of your Business Rule?
I'm attempting to use this script and receiving the following error:
Cannot validate argument on parameter 'TargetPath'. The argument is null or empty. Supply an argument that is not null or empty and then try the command again.
This is my modified version of the script:
$Office = "%Office%"
$departmentMap = # TODO: modify me
"Dallas"="OU=USA-Dallas,OU=Adaxes,DC=mydomain,DC=local";
"London"="OU=GBR-London,OU=Adaxes,DC=mydomain,DC=local";
$targetOU = $departmentMap[$Office]
if ($targetOU -eq $NULL)
$Context.LogMessage("No target OU specified for Office '$Office'", "Warning")
Move-AdmObject "%distinguishedName%" $targetOU
Michael,
The value reference for the Office property is not %Office%, it is %physicalDeliveryOfficeName% because the LDAP name for this property is physicalDeliveryOfficeName. Here's the script modified to your needs:
$Office = "%physicalDeliveryOfficeName%"
if ([System.String]::IsNullOrEmpty($Office))
    $Context.LogMessage("The Office property is not specified", "Warning")
if ([System.String]::IsNullOrEmpty($targetOU))
We tested the script in our testing environment and it works perfectly. We didn't manage to reproduce the error that you get.
Thank you that did the trick!
asked Jun 3, 2021 by RayBilyk (230 points)
Hi, Is there a way to give an (by default for every user) automatic lockout expiry to each new user account that is created? I know there's a way of adding expiry ... -Feb-2013, then it should by automatically get locked out again on 04-Mar-2013. Regards,
asked Sep 29, 2013 by jeet (80 points)
I'm unable to Browse the AD OUs my Security Role Trustee is Assigned Over in my Custom Web Portal. When clicking Browse it states "No objects to display". How can I rectify this issue?
asked Feb 1, 2013 by mdeflice (350 points)
Hi! Can ADAxess be used to populate a AD group with computer objects who's name partly matches a AD username from another group? I'e let say we have a group named ' ... channel until problem is solved by just adjusting which group they belong to .... /Kaj
asked Jun 12, 2018 by KajLehtinen (650 points)
7,805 comments
545,184 users
