Working within a DoD environment all interactive user accounts are required to have an @mil suffix. Within the application though I am unable to make the required change to anything but the default domain suffix. Is it possible to setup a business rule to change the suffix based on the different employee types within our environment? The employee types consist of CTR, SVR, WKS, ADMIN, and APP.
by (100 points)
Hello Jason,
Have a look at the following tutorial: https://www.adaxes.com/tutorials_Simpli ... Office.htm. If you want to generate the UPN Logon Name based on the Employee Type of a user, the action sets in the Business Rule, Custom Command or Scheduled Task should look like the following:
I have thought but this but the issue is the samAccountName does not always match the the upn login name. Often times the upn contains the users EDIPI or alt token information (which can vary in length), where the samAccountName is generally first.last.(employeetype).
example:
samAccountName - joe.user.svr
UPN - alt.joe.user.svr-1234567890@defaultdomain.name
Where it should be:
UPN - alt.joe.user.svr-1234567890@mil
Hello Jason,
Thank you for the clarification. This can be done via a script. You can adjust the following script from our repository to meet your needs: https://www.adaxes.com/script-repositor ... t-s449.htm.
Worked great, thanks for the help.
Hi, I want to change the default UPN suffix for user creation. We only have a single UPN suffix we use at our organization however when we create a user using the web ... We only ever want to use the @mycompany.com so a list of options isn't requried.
asked Jun 29, 2022 by PeterG (40 points)
Is there a way to set a users' UPN Suffix within a business rule (PS script)? I've seen the script to update the suffix based on OU, but our OU structure ... primary email address, or to apply a particular UPN suffix based on department. Either method works.
asked Apr 3, 2017 by steve.newton (50 points)
Hello, is it possible to display menu with all UPN suffix when create new user ? Thx.
asked Jun 23, 2014 by mmichard (360 points)
I currently have a Custom Command that is configured for User objects, but I would like to perform actions against a Computer object in the same command. E.g. I have a ... Users, there's no Action Set to disable Computers. Is there a workaround here? Thanks!
asked Jul 28, 2020 by bavery (250 points)
This note is found in the documentation on how to configure allowed domains in Adaxes 2023. Allowed domain names can only be selected from the alternative UPN suffixes for on- ... required to pick up the change, or is there another way to trigger the update?
asked Jan 31, 2023 by dtb147 (290 points)
7,805 comments
545,180 users
