We have a problem with the way Adaxes detects % as variables in all PowerShell scripts.
We are configuring a HTML email template for all out going emails from the system and use HTML table with to set the sizes.
The sizing needs to have a % sign, for example:
<table width="100%" border="0" cellspacing="0" cellpadding="0" style="border-spacing:0;text-align:left;padding:0;margin:0">
Adaxes will think that this is a start of a variable. Is there anyway around this?
Regards,
ice-dog
by (170 points)
by (273k points)
Yes, you are right, in the PowerShell editor, the percent character (%) is recognized as the beginning of a value reference. To remedy the issue, duplicate percent characters where they are not related to value references. I.e. replace % character with %%. For example, the line you referenced will look as follows:
<table width="100%%" border="0" cellspacing="0" cellpadding="0" style="border-spacing:0;text-align:left;padding:0;margin:0">
Thank you
That's an impressively quick response
ice-dog
Hello, I have few business rules for AD account rename to validate input data and make sure username selected is unique in AD, but sometimes it fails with very non-explaining error " ... a "Before updating a User" rule BR14 - is a "Before renaming a User" rule
asked May 14, 2018 by DLe (760 points)
I'm creating a powershell script to handle all the 'modify user' steps, instead of having them be individual steps in Adaxes. This script runs after we fill out a form. A ... empty parameter considered as either a "tab" or "4 spaces" ? Thanks for your help.
asked Dec 12, 2022 by lw.fa (130 points)
I have written a de-provisioning job as part of removing a terminated employee's access. This job disables the account, resets the password, sets the account description to ... part of the de-provision job. Could I possibly get help with this? Thanks!
asked Jan 27, 2014 by PunkinDonuts (360 points)
Hello Is it possible to reference a powershell script placed in a folder somewhere on the Adaxes server, instead of embedding them in each BR and CC ? I'm planning to install a powershell GUI product, for easy debugging. - Thanks
asked Feb 17, 2016 by Boxx.dk (2.6k points)
545,387 users
