Hi, how can I change Help Desk to something a little more specific like "Onboarding Portal"? Or a bit more catchy that our HR will like rather then see Help Desk in the left hand corner.
by (140 points)
Disregard... figured it out :D
asked Mar 29, 2023 by Vish539 (310 points)
Hello, I want to give the ability for the Help Desk to add a new IE trusted site. I did a Custom Commands that works well. $scriptBlock = Powershell { Import-Module Adaxes Import ... ( $Zone). The GPO name ($GPOName)will never change. It is possible to do it?
asked May 31, 2016 by tentaal (1.1k points)
asked Mar 21, 2023 by Vish539 (310 points)
7,819 comments
545,407 users
