Is there a way to build a list of allowed values for an attribute based on the value of another attribute?
I explain: I'd like that allowed values of department attribute depend on the value selected in list of allowed values for OU attribute. The same for division attribute, allowed values could depend on department value selected.
Am I clear enough?
I'm not sure this is a common usage, but it would be really usefull for us.
Thanks for your response,
Yoann
by (180 points)
Hello Yoann,
Unfortunately, such functionality is currently unavailable. It is in our TODO list.
As a workaround, we may suggest that you create a Business Rule that will get the value of one of the properties and then check whether the value of another property falls within the range of allowed values. If it doesn't fall within the range of allowed values, the Business Rule will cancel the operation. Take a look at the Validate/Modify User Input Using a Script Tutorial. If you have any difficulties withn the Business Rule, we may help you.
Hi We've currently have 2 instances of Adaxes running in our environment. The first is a legacy standalone system and the new is a HA environment. We needed to get some things ... system so that it can be wiped and rebuilt. Is tihs possible at all? Thanks Matt
asked Nov 12, 2020 by chappers77 (2.0k points)
What is the difference between "Disable Account", "Lock Account", "Account Expired" Please explain the differences and when to use each. Thank you
asked Apr 26 by hhsmith (60 points)
We are planning to use Adaxes in our environment and before proceeding, we need to understand the firewall port requirements for Adaxes service to work. What are the firewall ports needed between Adaxes and AD domain controller?
asked Jan 24 by Renugopal (120 points)
For all our shared mailbox in Exchange we create security groups to manage the sendas, send on behalf and full access permissions. Users go via the web interface and select the ... should I now use? Unless there is a better approach I am open to ideas.
asked Dec 22, 2023 by MikeBeattie (90 points)
In the Adaxes GUI I see three forms of delegation: Send As Send on Behalf Of Mailbox Rights In the WEB GUI there are also three forms of delegation: Shared Mailbox Members Full ... Behalf Of" missing on the WEB? -- Morten A. Steien For reference GUI: WEB:
asked Jul 14, 2023 by Morten A. Steien (300 points)
545,379 users
