I did some testing around Fine Grained Paswword Policy and Adaxes. See my previous post. It seems to be OK.
HOWEVER
If I use the Adaxes web portal to view a user's account it shows the password expiry as per the default domain policy and not the true one as of the FGPP as implemented by Adaxes.
by (280 points)
The Password Expires field of the Web Interface displays expiration time based on the Default Domain Policy instead of Fine-Grained Password Policies. This is a bug that we will fix in one of our nearest releases. Thank you for the bugreport.
For now you may see the password policy applied to the user by clicking the View Password Policy link on the Reset Password dialog:
Thanks for the info.
Just to clarify I am NOT talking about the self service web portal but the helpdesk portal. When searching and displaying a user you see the wrong password expiration date.
Doesn't matter. This bug does not depend on the Web Interface type. Thanks again for the bugreport!
Was this fixed in new version?
We didn't manage to include the fix for the bug into Adaxes 2013.1 release. Approximately in a month we are going to release a minor update for Adaxes 2013.1 that will include the fix.
I have created a fine grained password policy in Adaxes with expiry dates in 100 days. It appears to work. However ADUC still show the accounts expirying in 42 days as ... Adaxes or only reflect the domain policy even if it no longer applies to the user?
asked Nov 13, 2012 by It_helpdesk (280 points)
an OU is created in the Active Directory. but when I'm trying to select that in "password policy". the Adaxes is not allow for me to choose OU. only AD users and groups can be selected. is there any way to choose OU?
asked Sep 23, 2020 by justinh (60 points)
We are in the process of implementing LAPS in our environment. Is there an option / way to get the password from the Adaxes web portal?
asked Jun 15, 2020 by peggleg (110 points)
Hello, I am having issues with Reports not matching the results in the Console and Web UI. Below, you can see that the Adaxes Console only has 8 Workstations listed, but on the ... UI. Any help is appreciated, let me know if there is any questions. Thank You!
asked Jul 23, 2023 by Edogstraus00 (470 points)
I would like to show a couple of Adaxes Virtual Attributes in the Web Portal. I've added them in the Configuration, see the 1st screenshot below. I've ... . Any help? Virtual Attributes added Security Role has permissions Virtual Attributes not showing up
asked Jul 29, 2020 by nate2 (90 points)
545,379 users
