Hello
We are looking to optimize one of our most used scripts. The script is kinda slow when working against a domain containing over 15 terminal servers. We are using the same script against several domains, therefore we can not specify the names or ou's of the servers.
So if anyone has any suggestions on how to make this script work faster, it would be greatly appreciated!
Import-Module Adaxes
$credentialDirectoryPath = "C:\Credentials"
$targetUserName = "%username%"
# Get name of the user's domain
# Get credentials for the domain
if(!(Test-Path -Path $credentialDirectoryPath))
    $Context.LogMessage("The credentials folder was not found. Make sure that $credentialDirectoryPath exists.", "Error")
$directory = Get-ChildItem -Path $credentialDirectoryPath -Filter $domainName
if(!$directory)
    $Context.LogMessage("The credentials folder for domain $domainName was not found.", "Error")
# Read credentials for the domain from the file
$file = Get-ChildItem -Path $directory.FullName
if(!$file)
    $Context.LogMessage("The credentials file for domain $domainName was not found.", "Error")
$userName = (Get-Content -Path $file.FullName)[0]
$passwordEncryptedString = (Get-Content -Path $file.FullName)[1]
$password = ConvertTo-SecureString -String $passwordEncryptedString
$credential = New-Object System.Management.Automation.PsCredential($userName,$password)
# Get all computers from the user's domain
$computers = Get-AdmComputer -Filter {(Enabled -eq $True) -and (operatingSystem -like "*Server*") -and (name -like "*MF*" -or name -like "*ctx*" -or name -like "*xap*" -or name -like "*TS*")} `
    -AdaxesService localhost -Server $domainName
# Create a remote PowerShell session
$session = New-PSSession $file.Name -Authentication Negotiate -Credential $credential
foreach ($computer in $computers) {
    $result = Invoke-Command -Session $session -ArgumentList $computer, $targetUserName -Scriptblock {
        param($computer, $targetUserName)
        Import-Module PSTerminalServices
            $session = Get-TSSession -ComputerName $computer.DNSHostName -UserName $targetUserName
            if($session)
                return "User has a " + $session.State + " session on " + $computer.Name
    if($result)
        $Context.LogMessage($result, "Information")
Remove-PSSession $session
by (960 points)
We've given our script guy the task to test the script and see whether it is possible to improve it. I'll update the post as soon as he comes up with something.
Our script guy has come up with a certain performance improvement. However, keep in mind that often the time required for a script to run depends on your environment. In this particular case the performance of the script may depend on whether all of the computers that are polled are available. If some of the computers are unavailable (e.g. powered off), the script will still try to connect to them, and this involves the standard timeout required to identify that the computer is down.
Here's the updated version of the script. Instead of using the Invoke-Command cmdlet in a foreach loop, it passes an array of computers to the Invoke-Command cmdlet, and only connection to the computers is performed in the foreach loop.
if(!$directory)
if(!$file)
$result = Invoke-Command -Session $session -ArgumentList $computers, $targetUserName -Scriptblock {
    param($computers, $targetUserName)
    $sessionsInfo = @()
    foreach($computer in $computers)
            if($session)
                $sessionsInfo += "User has a " + $session.State + " session on " + $computer.Name
    return $sessionsInfo
if($result -eq $NULL)
    $Context.LogMessage("No session information for the user.", "Information") # TODO: modify me
foreach($sessionInfo in $result)
    $Context.LogMessage($sessionInfo, "Information")
by (960 points)
Thank you very much!
We added a bit to the script to avoid offline servers, as per your suggestion. These two together made the script execute about 15 sec faster :)
Here is the complete script:
if(!$directory)
if(!$file)
    $sessionsInfo = @()
    $online = Test-Connection -Cn $computer.DNSHostName -BufferSize 16 -Count 1 -ea 0 -quiet
    if($online){
            if($session)
    $Context.LogMessage("User has no active sessions", "Information")
Well, we think that this is as much performance gain as you can get in this case. Thank you for your update on the script. ;)
This is from within a custom task. Account has proper RBAC permissions and I can do this from a normal powershell window.
asked Mar 26 by ZoomGhost (340 points)
The csv I am using contains firstname,lastname,fullname,pass I will use fullname for both fullname and log on name and pass for the password.
asked Mar 26 by mightycabal (1.2k points)
I am trying to get information from a built in report, and add it to a custom attribute. I need to get the IP address in the built in report " ... Update user $user = $Context.BindToObject($userPath) $user.Put($propertyName, $userstaticIP) $user.SetInfo() }
asked Dec 16, 2025 by apruitt (470 points)
I'd like to run a powershell script Before Updating a User Account, which I can check what the exchange mailbox permissions before and after the change. I need to be able to both report on ... - not SID's or DN's. What's the best way to do that? Thanks, Jay
asked Oct 2, 2025 by jaymallery (60 points)
