I have the HelpDesk web interface setup and I have a Create User task that our help desk can user to create new users. I have a Property Pattern setup that sets some default values including the User Logon Name (pre-Windows 2000). When I'm creating a new user using that form it populates the User Logon Name (pre-Windows 2000) with the value I've set as the default (%firstname:lower,1%%lastname:lower%) and that in turn populates some other fields that are linked to the %username% alias. If I try to change the value of the User Logon Name (pre-Windows 2000) field it changes and everything in the form updates accordingly but when I click the Create button and the account gets created those changes are thrown out and it users the value from the property pattern.
Perhaps I'm misunderstanding the Default Value of a property pattern property. I thought it would just populate a default value and if it was changed then it would accept that change but it appears that what ever is setup in the property pattern is what will be put in the AD account when it's created. So my question is this (sorry about the long winded explanation): How do I populate an "initial" value but still allow it to be changed on the web form and subsequently put into AD? The reason is that occasionally we have users that end up with the same account name using our naming method and it needs to be changed from what the default is. Hope that all makes sense.
by (520 points)
Have you selected the 'disable' option in the 'speech bubble' icon to the immediate right of data entry field?
If you have customised the text then this option doesn't appear any more (feature request!) though.
Rgds
bemho, actually you got it right, the value generated by the Property Pattern is just a default value. If you change the value generated by a Property Pattern, Adaxes should accept the modified value.
To help us troubleshoot the issue, can you send us the configuration of your Web Interface that you are experiencing issues with? To do this:
  1. On the computer where your Web Interface is installed, open the folder that contains the Adaxes Web Interface site that you are experiencing issues with. By default, Adaxes Web Interface sites are installed to the following folders:
    • Administrators:
    • Help Desk:
    • Self-Service:
  2. Locate the Web.config file.
  3. Attach this file to a letter and send it to our support email (adaxes@softerra.com).
Will that break the current web interface site or can I have them both running at the same time?
No, it won't break anything. Adaxes allows you to install any number of Web Interfaces.
Ok. I finally got around to installing another Web Interface on a different server and restored the configuration from the current server to it and it works properly (accepts the username change that I input). So with that in mind, how do I go about fixing my actual server? Just restore the configuration on it?
Hmm, that's really strange...
I suggest you try the following:
  1. Clean browser caches
    If that doesn't help
  2. Restore the configuration of your Web Interface
  3. Reinstall the Web Interface (without reinstalling your Adaxes service)
Thanks for all the help with this issue. I never did figure out why it was happening, but I just installed 2013.1 and tested it out and everything is working as it should. Again, thanks for all the help.
I'm testing making changes to a mailbox that is synced between AD and Office365. During changes updates are not reflected back. I'm prompted that the replication with AD Connect has ... in the web interface. If I go to the console I can see the change.
asked Aug 6, 2020 by ComputerHabit (790 points)
Hello, I am not getting email responses from support because of a technical problem. In the meantime, I figured for I would post here. I am using the new heldesk web ... how the helpdesk interface is configured and what the user's screen looks like: Thanks.
asked Jul 20, 2018 by Jasonmh (540 points)
In the web interface, I would like to display the "Distinguished Name" property but it is not showing it as it would when using ADUC or even in the Adaxes Admin Console. Is ... I would like it to display like this: CN=Mark Smith,OU=Sales,DC=Fabrikam,DC=COM
asked Jan 15, 2020 by mark.it.admin (2.3k points)
I created an entry in the AttributeFriendlyNames2.eng.xml file, but the real name still shows instead of the friendly name in both the Web Console ... ;/ldapName> <friendlyName>FAX Coversheet</friendlyName> </friendlyNameItem> Any ideas?
asked Jan 5, 2017 by Kikaida (1.1k points)
Is it possible to only allow a user to unlock their account from the web interface? We have a group of Mac users who we'd like to be able to unlock their accounts through the web but use a different service for changing their passwords.
asked Jun 30, 2020 by scoutcor (120 points)
3,351 questions
545,086 users
