When I make a change to a specific interface type via the "Adaxes Web Interface Customization" application, those changes are not getting updated on the corresponding site, even when resetting IIS.
For example, on the Self Service interface I went to AD Management --> Customize Forms and Views... and removed all sections from the User object type but "Account," removed all section fields in "Account" but "User Logon Name" and "Password Expiration Date," and clicked apply and OK. When I logged into the site with a test user ID setup to mimic a typical user, all sections were present. Moreover, in the Account section, all fields were present.
Based on the documentation I have been seeing on the site, these changes should apply automatically without an IIS reset. Am I missing something?
by (80 points)
First of all, make sure that you are making changes to the correct Web Interface type as forms and views are configured separately for each interface type (Administrator, Help Desk or Self Service). In your example, the Self Service Web Interface type should be selected in the Interface type drop-down list at the top of the Adaxes Web Interface Customization window.
Also, you should remember that if you are using a Home Page Action to view a user's account and have setup the Home Page Action to use a customized form, the form of the Home Page Action will not take the changes that were made to the default form. So, if you are using a Home Page Action, you need to customize the form of the Home Page Action instead. For information on how to customize the form used for the View User Home Page Action, see The 4th step of the View Object section in the Configure Home Page Actions Tutorial.
This is resolved. We weren't aware, but it turns out the Web Interface Customization applcaiton doesn't like it when you change the physical path of the Admin, Help Desk and Self Serivce sites in IIS from that which is intially set by the Adaxes installer. As soon as we moved the files back to their original location and restored the original physical paths in IIS, the site appeared as expected.
If you move the folders that host Web Interface sites from the folder where they are originally located, the Web Interface Customization tool will not be able to find the Web Interfaces. However, if you just rename the folders, but leave them in the same folder that they are originally located, which is C:\Program Files\Softerra\Adaxes 3\Web Interface\ by default, the Web Interface Customization tool will accept such changes.
Hi, I am trying to setup a Home Page action in the Help Desk portal to modify a User account, for this i want to specify the default value of a property to be the ... the user account i am modifying to get the default value? Thanks in advance for any help!
asked Dec 1, 2016 by sam.webster (370 points)
Is there a way I can add some informational text to this self-service change password screen? If it's not built in I'm fine with editing a config file. Thanks Ryan
asked Apr 4, 2014 by ryan_breneman (920 points)
We're experiencing an error opening the Web Interface Customization module. There don't seem to be any relevant posts here, nor can I find any obvious problems in the event ... will be empty. You can add a property name manually by clicking Add Extra button."
asked May 13, 2014 by theckel (520 points)
Is it possible to hide the header and footer completely when using iframe and automatic login? I see options to hide individual sections, but I am not able to hide the Home, Logout, username, etc. Is it possible to show just the main content section?
asked Jul 9, 2013 by sdavidson (730 points)
To the left of the user object there are several custom commands showing. I don't want our service desk to see them. Why are they showing? How do I remove them. Must be something simple. They only see these when looking at a user Object.
asked Jan 17 by mightycabal (1.0k points)
545,381 users
