Whenever I try to use the move mailbox command with the newest version of Adaxes, I encounter this error:
The term 'New-MoveRequest' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
I'm running this on the admin client that has the full Exchange tools loaded already.
by (470 points)
That error means that the account of the Adaxes service administrator doesn't have the permission to execute PowerShell cmdlet New-MoveRequest.
You need to assign the Adaxes service account to an Exchange Management Role. For more details, see
Understanding Management Roles.
That was it. That is the first time the service had to be granted Exchange admin rights eventhough other scripts had performed the same function in previous versions.
You are welcome :)
That's because Adaxes establishes a remote PowerShell session with an Exchange server and performs operations remotely (as recommended by Microsoft).
BTW, we recommend assigning the service account to the Organization Management role group in Exchange. This role group provides administrative access to the entire Exchange 2013 organization and can perform almost any task.
If, for some reason, you do not want to provide the account administrative access to your Exchange organization, you need to assign the account to the following role groups in Exchange:
Hello, we are in a migration phase from Exchange onPrem to Exchange Online. Since not all of our sites will be migrated at one time we are looking into a way to migrate ... an alerting / sending out a mail if the batch is not succesful? Thanks and KR Christian
asked Mar 21 by User0815 (40 points)
asked Aug 1, 2023 by curtisa (210 points)
Hi Team! I'm currently looking for a solution to create an exchange mailbox on-premise, sync it to Office 365 and assign the license in one business rule. I didn't ... solution from our side? Please let me know how to configure this. Best Regards Marco Jandl
asked Apr 6, 2022 by marco_jandl (60 points)
We are experiencing issues with mailbox moves failing between AD sites. If we use the Exchange Move Mailbox task, it works fine for small mailboxes (under 30MB). Once the ... is logged, nor do I see any events logged on the Exchange servers in question.
asked Oct 30, 2013 by DFassett (710 points)
Hello, I would like to ensure that before a computer object is moved in Adaxes, the user must enter a ticket number, and after the input, the PC is moved to ... prompts the user to enter a ticket number before the move/delete operation? Kind regards, Fabian
asked Mar 20 by fabian.p (150 points)
545,375 users
