we recently upgraded to version 2013.1. Everything was working fine. We have multiple websites and noticed, that on custom websites, newly created Active Directory filters do not work anymore. We get an error "The NAME OF THE OU object does not exist". It is a know error?
Regards,
Andreas
Hello Andreas,
Are you sure that you performed all the steps that must be performed during an upgrade? For a list of the necessary steps, see Upgrade to New Version. In particular, if you have custom Web Interface sites created in addition to the default 3 sites, pay attention to the 5th step that requires you to update the files in the folder for the custom Web Interface with files from one of the existing Web Interfaces (for Administrators, Helpdesk or Self-Service), and then reconfigure the custom Web Interface.
Whenever i use exchange cmdlets through remote powershell from a script launched by Adaxes, i get this warning message in the execution log: "Some imported command names include ... now. I won't delete the post, should anyone else experience these problems.
asked Feb 13, 2014 by kjesoo (960 points)
Hello, In previous versions I used the instructions in this post Handling child objects to view Bitlocker Recovery Key's for computers. After upgrading to 2013.2 these instructions no longer ... way to view it. Help... this is a critical issue for us. Thanks.
asked Oct 30, 2013 by DFassett (710 points)
Hello, after upgrading to 2014.1 the web interface is throwing lots warnings pertaining to groups: Failed to build a list of groups, in which user 'Some.Person@domain.local ... very noisy with these warnings. :) Has anyone else experienced this? Any ideas?
asked Aug 29, 2014 by EgotisticalGiraffe (350 points)
Hello, we installed Adaxes on a clean Windows 2012 R2 system. Clean means there is no other software installed. After starting the Web interface configurator the screen hangs and ... time to get a cup of copy. Any advice how we can investigate this behaviour?
asked Jul 12, 2018 by HorstR (460 points)
3,365 questions
545,290 users
