I have been trying to figure out the best way to have multiple Business Units and locking a manager of a business unit to that business unit and only that business unit.
For example, the manager of Example Company 1 are Test User 1 and Test User 4. They can edit anyone's details/password in Example Company 1 but cannot even see Example Company 2 or anybody in that business unit or anybody else in that domain. Test User 2 and Test User 3 cannot change anybody else's password but their own.
Example Company 1
- Test User 1 (Manager)
- Test User 2
- Test User 3
- Test User 4 (Manager)
Example Company 2
- Test User 5
- Test User 6 (Manager)
Is this possible and how would I go about this task. I've been able to work with Blind Users and that is only a part of the solution and doesn't give me all the functionality that this particular situation is requiring.
by (80 points)
Today we are releasing Adaxes 2011.1, which allows you to do what you need. As soon as all the data is uploaded, I'll post here a link to a tutorial that describes how to do what you need.
Eugene , you are such a great wealth of knowledge! Thank you! Just downloaded 2011.1 and installed it! :D
This is exactly what we were looking for! Thank you soo much! Is there a way the default page they are redirected to? Instead of being home, it would always be their own "My Properties"?
Yes, it is possible to do this. However this option is not available in the Web Interface Customization tool, and you'll need to modify the Web.Config file manually.
Make sure the Web Interface Customization tool is NOT running.
Using a text editor open the Web.Config file of the Web Interface that you want to configure. By default this file is located in the following folder:
Administrators: C:\Program Files\Softerra\Adaxes 3\Web Interface\Admin\*
Help Desk:
Self-Service:
C:\Program Files\Softerra\Adaxes 3\Web Interface\SelfService\*
Set the useMyPropertiesPageAsDefault attribute of the web.ui XML element to true.
<configuration>
  <softerra.adaxes>
    <web.ui doNotShowExecutionLogForSucceededOperation="true" useMyPropertiesPageAsDefault="true">
Just a note, if it does not exist in the context such as
<configuration>
   <softerra.adaxes>
     <web.ui adaxesConfigurationSetId="{59f55590-4eff-4721-9aa7-77f26a861b49}">
Adding it will make it work just fine.
<configuration>
   <softerra.adaxes>
     <web.ui adaxesConfigurationSetId="{59f55590-4eff-4721-9aa7-77f26a861b49}" useMyPropertiesPageAsDefault="true">
Thank you for the note!
I have an OU structure as follows: Computers |- Servers |- A |- B |- C Groups |- Computers | |- A Phase 1 | |- A Phase 2 | |- A Phase 3 | |- B Phase 1 | ... as the naming scheme is fairly standard. Is this doable, and if so, can you guide me on the right path?
asked Nov 17, 2023 by bennett.blodinger (60 points)
Hi, we would like to combine different OUs into business units for differnt local helpdesk teams. We started to add OUs with this logic for Business Units This give us a ... messy as every item is shown at once and not structered anymore. Any solution here?
asked Jul 4, 2023 by wintec01 (1.1k points)
Hi, When viewing a business unit in the web interface, in the title bar where the BU name is there is an Other Menu with the Add To Basket option in it. I thought this ... itself which I don't want users to do. Is there a way to remove this function? Thanks
asked Oct 29, 2014 by dazbo (390 points)
We used to run AD Audit and it would provide additional details on what was locking a user's account (workstation name, application, etc...). Is there are way with Adaxes ... on what is locking an account? Or a way to pull historical data on locked accounts?
asked Nov 16, 2020 by pulsifers (20 points)
We are trying to extend our Adaxes management to O365 / Azure only user objects. Currently we use employee type to add traditional active directory accounts to business units and ... so, can this be used to create dynamic mail enabled security groups in O365?
asked May 3, 2022 by adaxes_user2 (40 points)
3,365 questions
545,268 users
