I wanted to contribute something back to the forums since I am always asking so many questions. I was able to find the answer on my own after I searched the forums/site without finding anything.
I was looking to change the Welcome message on the login page which said "Welcome to Softerra Adaxes 2011.1". I was able to find the localization file which is under
C:\Program Files\Softerra\Adaxes 3\Web Interface\Admin\App_GlobalResources\Strings.resx
This file has all the associated data for language settings. The setting I was looking for was
<data name="WelcomeTemplate" xml:space="preserve">
     <value>Welcome to XYZ Company's Self Service Portal</value>
</data>
Hope this helps some one in the future!
by (80 points)
Thank you very much for this post!
In the next version this setting will be available in the Web Interface Customization tool.
I'm going forward on that topic as i would like to translate specific actions we have in our Web interface (create user with a specic form). Is it possible ? Also, i noticed that "Manage Group Membership" action is not translated in French.
Thanks in advance
Yes, it is possible to translate Home Page actions. For more details, please see Configure Home Page Actions.
There is no built-in "Manage Group Membership" action. It means that you created the action by yourself and specified English texts for it. You can also translate the action by editing it in the Web Interface Configuration Tool.
Yes you're right, this is a custom action.
But i cannot see how to translate a custom action, i mean, how to provide text for both english and french languages (i double checked the tutorial).
Unfortunately currently it is impossible.
Hi team, I am trying to set a primary smtp address to a user based on input during creation. If someone set a specific email in form, this is stored in customAttributeText3 and ... a specifc email address as primary? Do I need to run a PS command to set it?
asked Oct 13, 2023 by wintec01 (1.1k points)
Hi I need to send an HTML email via PowerShell, but my SMTP server needs authentication. Is there a way to get the SMTP settings configured for Adaxes via a script? Thanks
asked Sep 29, 2023 by chappers77 (2.0k points)
I'm trying to modify mailbox settings to add additional email addresses to a user after creation. This is a hybrid on-prem and Exchange Online with E5 licenses. Everything works up ... to a different OU during the process so I know the user exists. Any ideas?
asked Mar 6, 2023 by Michael Long (70 points)
Hello All, it is possible to configure SMTP mail setting using Exchange Online with modern authentication and Azure security defaults enabled? Currently I have setup local IIS ... defaults but I would like to connect to my more secured tenant. Regards Ivaylo
asked Dec 6, 2022 by ivaylo.valkov (100 points)
ADAXES version is 3.13.18106.0 trying to set up "outgoing email server" for email notification. We are using google smtp-relay which require "SSL" After setting it ... their own credentials, such as the internet information server, are not affected by this."
asked May 20, 2021 by justinh (60 points)
3,365 questions
545,274 users
