I saw that 2013.2 does logging to SQL...is there any docs on that? I would like to use that but my DBAs are asking 50 questions and would like to get them info
by (490 points)
Unfortunately, we didn't manage to prepare documentation for MS SQL support for the new release. It will soon be available.
Adaxes supports MS SQL Server 2005, 2008, and 2012.
To set up Adaxes to store log records in an MS SQL database:
  2. In the Console Tree, expand the service node that represents your Adaxes service.
  3. Expand Configuration.
  4. Right-click Logging and select Properties in the context menu.
  5. On the General tab of the Logging Properties dialog, switch the radio button to External database (MS SQL).
  6. Press the arrow button embedded In the Server name field and select an MS SQL Server that hosts the database where log records will be stored. If the necessary MS SQL server is not available, simply type the address of the server in the field.
  7. Press the arrow button embedded In the Database field and select the database where log records will be stored. If the necessary database is not available, simply type the address of the server in the field.
    Note: Adaxes default service administrator (the user that you specified during Adaxes installation) should be Database Owner (dbo) of the selected MS SQL database.
    Note: The database should be empty. Adaxes will set up the database, including creating the necessary fields and tables, automatically.
  8. To check whether Adaxes can connect to the database, press the Check button.
thats seems pretty straight forward, I think they had concerns over the data type "Blobs"?
Could you be more specific? What are their concerns?
Hi team, I am trying to set a primary smtp address to a user based on input during creation. If someone set a specific email in form, this is stored in customAttributeText3 and ... a specifc email address as primary? Do I need to run a PS command to set it?
asked Oct 13, 2023 by wintec01 (1.1k points)
Hi I need to send an HTML email via PowerShell, but my SMTP server needs authentication. Is there a way to get the SMTP settings configured for Adaxes via a script? Thanks
asked Sep 29, 2023 by chappers77 (2.0k points)
I'm trying to modify mailbox settings to add additional email addresses to a user after creation. This is a hybrid on-prem and Exchange Online with E5 licenses. Everything works up ... to a different OU during the process so I know the user exists. Any ideas?
asked Mar 6, 2023 by Michael Long (70 points)
Hello All, it is possible to configure SMTP mail setting using Exchange Online with modern authentication and Azure security defaults enabled? Currently I have setup local IIS ... defaults but I would like to connect to my more secured tenant. Regards Ivaylo
asked Dec 6, 2022 by ivaylo.valkov (100 points)
ADAXES version is 3.13.18106.0 trying to set up "outgoing email server" for email notification. We are using google smtp-relay which require "SSL" After setting it ... their own credentials, such as the internet information server, are not affected by this."
asked May 20, 2021 by justinh (60 points)
545,388 users
