We've got a business case where we want the initiator of an account creation process to have the manager of the account 'hard-set' as *their* manager (as part of a 'break glass' procedure where a normally non-permissioned user can create an account, but we force their manager to be 'made aware' and be responsible for the account etc).
The issue I have is that I cannot auto-insert the attribute in the correct (DN) format in the data input form; I can insert initiator-ManagerUserName, Fullname etc, but not initiator-ManagerDN, as it's not an available attribute.
Is there a clever way for me to achieve this, or can you add this attribute to the list of those available in a future release?
by (1.6k points)
As far as we understand, you want the initiator's manager to also become the manager of the new user. Are we getting you right? If so, it can be easily done with the help of a PowerShell script run a Business Rule. The Rule will be triggered after creating a new user.
Also, we've added your suggestion to our TODO list. Thanks!
Yep - this is our workaround.
It's made slightly harder by the fact that we have made the Manager field mandatory, so we first insert the initiator and then change it with a business rule as you suggest.
Starting from the Adaxes 2014.1 released today, you can use the %adm-InitiatorManagerDN% value reference that is resolved into the distinguished name (DN) of the manager of the operation initiator. Find the latest build here.
Upgrade Instructions.
Hello, I would like to ensure that before a computer object is moved in Adaxes, the user must enter a ticket number, and after the input, the PC is moved to ... prompts the user to enter a ticket number before the move/delete operation? Kind regards, Fabian
asked Mar 20 by fabian.p (150 points)
I'm in the process of creating a Web interface for requesting IT accounts. Upon submission, I want to run a Powershell script that will create an item in a Sharepoint task list.
asked May 14, 2021 by sandramnc (870 points)
I am trying to have a scheduled job that will hide groups that are empty and I can not seem to figure out how to do it.
asked Aug 20, 2021 by hgletifer (1.3k points)
By default The Sign in Page for adaxes is Ex. adaxes.contoso.com/adaxes. After that I already set up the rules to redirect the user to the page that match their permissions ... can I make the Login Page : adaxes.contoso.com (stripping out the /adaxes) Thanks
asked Oct 23, 2019 by davidotz8 (120 points)
In past I am able to enable Auto Logon (Windows Integrated Auth) in our Internal Adaxes Server (full server) and in same time Form based auth for DMZ Based web server ... login when internal network but when outside, they should get the auth form for login.
asked Feb 20, 2019 by Brajesh (460 points)
3,371 questions
545,353 users
