We're looking at enabling the Lync support in Adaxes, but current it cannot find the pool\registrar servers etc.
I assume this is related to missing privileges (we don't run with Domain Admin rights); do you have a list of the minimum rights required?
by (1.6k points)
To remedy the issue, you need to grant the user, whose username and password were used to register the domain with Lync in Adaxes, appropriate permissions. For more information, take a look at the following article by Microsoft: http://technet.microsoft.com/en-us/libr ... 25917.aspx.
Thanks for this, but am not 100% sure what we should be checking.
The Adaxes service account is registered in Lync\AD to manage Lync settings (e.g. we can use the remote PS session script method to enable\disable Lync mailboxes), but we cannot enumerate the pool data etc.
Are you saying that we need to grant the service account additional Lync privileges (which would make sense as you pointed me to a Lync permissions FAQ), or something else?
It's the 'registering the domain with Lync in Adaxes' bit that's confusing!
It's not a big deal as, as intimated, I can use the remote PS option, and as we have more tasks than just enabling\disabling accounts that require this method anyway.
Cheers
Yes, we mean Lync privileges. If you register a domain with Lync in Adaxes, the credentials that you used when registering the domain will be used to perform operations in Lync, and thus the account that you specified should have sufficient permissions.
What permissions are required, other than Domain Admin, to edit the Adaxes configuration (business rules, property patterns, custom commands, etc.) in the console and the edit the web portal configurations in the AdaxesConfig web site?
asked Dec 6, 2019 by RickWaukCo (320 points)
Hello, I got a clear request from our Service Desk "for all modifing actions" we need a ticket number. That means I'm looking for a way to pop-up a small screen to ask for the ... ... But until now - I was not able to find a solution. :cry: Many thanks, Horst
asked Jul 4, 2018 by HorstR (460 points)
Hi all, I get the error below when enabling a user for Lync. I have opened port 5986 for winrm over https and have verified the correct certificates ... winrm quickconfig -transport:https". For more information, see the about_Remote_Troubleshooting Help topic.
asked May 8, 2017 by joshua.amune (50 points)
Hi- When I attempt to set this up, in my drop box, I have "no pools found" and is unable to enter the pool. Why can't I enter the pool or what has to happen in order for Adaxes to see that we have pools available?
asked May 29, 2014 by MeliOnTheJob (1.7k points)
Hi everyone, we're getting the below error when enabling a user for Lync: Connecting to remote server failed with the following error message : WinRM cannot process the request ... box' Lync enablement feature. Any ideas what might be going on? Thanks again!
asked Dec 6, 2013 by EgotisticalGiraffe (350 points)
7,806 comments
545,206 users
