hi-
I am setting up a scheduled task that will disable expired accounts and move them to a specific OU. I'd also like to send the results to my manager.
Would including "Operation: %adm-OperationDescription%" in the send email action list out all the accounts that were disabled and moved or is there a another attribute that will display it in a nicer way?
by (1.7k points)
As far as we understand, you would like to get a report on all the user accounts that were disabled and moved on each Scheduled Task run and send the report to a certain e-mail. Is that correct?
If that's correct, currently this cannot be done, but that's a good suggestion. We've added it to our TODO list. It will be available in one of the nearest releases.
ok, Thanks!
Hi Forum, is it possible in a Multi Server Setup to define One Server for scheduled Tasks? How does Adaxes choose the server executing the tasks? Thanks for your help Cheers
asked Jul 20, 2015 by esoAdxAdmin (650 points)
asked 6 days ago by Moodie007 (60 points)
Hi, I am trying to find a way to have a visual overview of all enabled tasks and when they are running. Example of another app which support this: Is this maybe planned in future?
asked Oct 4, 2023 by wintec01 (1.1k points)
When I enable a scheduled task, instead of running at the scheduled time they all run imeadiately. This is not good behavior as changes are written in a way to reflect the ... is being enabled. I am hoping there is a powershell command to stop this behavoir.
asked Jul 10, 2023 by mightycabal (1.0k points)
I have created 2 different scheduled tasks. One with PowerShell and one that is a if in group set an attribute. Both of these scheduled tasks are just looping. The PowerShell ... ) and then recreated. I have added send an email and I get emails each loop.
asked Apr 24, 2023 by william.malone (60 points)
7,806 comments
545,202 users
