I am trying to create a custom command that will wipe the users phones. The it seems the power shell is not taking the Variable %username%. Please see below
Import-Module Adaxes
Add-PSSnapin Microsoft.Exchange.Management.PowerShell.E2010
Add-PSSnapin Microsoft.Exchange.Management.Powershell.Support
$Target = %username%
Get-ActiveSyncDeviceStatistics -Mailbox $Target | foreach { Clear-ActiveSyncDevice $_.Identity -Confirm }
IS there and way to get it to take "$Target" in ther Get command?
by (40 points)
Hello, you need to enclose the %username% value reference in double quotes. Also, there's no need to import the Adaxes PowerShell module since you are not using any of its cmdlets.
$Target = "%username%"
Get-ActiveSyncDeviceStatistics -Mailbox $Target | foreach { Clear-ActiveSyncDevice $_.Identity }
Ok that seems to work with the "" Thank you . Now i am getting this error, "Cannot invoke this function because the current host does not implement it." Any ideas would be greatly appreciated.
The issue is in the -Confirm parameter. It forces the Clear-ActiveSyncDevice cmdlet to show a confirmation before wiping ActiVeSync devices, however Adaxes Custom Commands, Business Rules and Scheduled Tasks do not support prompting for confirmation from PowerShell scripts. Removing this switch will resolve the issue (see the updated script in the post above).
Is there a way to pull a report within Adaxes to find out how many computer objects a user will have associated to them?
asked Mar 2, 2022 by Tarun Sharma (20 points)
Hello, We need a report or a custom command that export all Active Sync devices details. Is there a way to do it ? Thanks :-) Michel
asked Feb 11, 2022 by zemitch (200 points)
For Office 365 Mailboxes, I get the following error:
asked Aug 27, 2019 by yourpp (540 points)
Maybe there is a better way to accomplish this, so I'm open to suggestion. We are in a hybrid setup between onprem and M365. When we create a new user, they are ... command in the previous step, right? If needed, I can provide the full script. Thanks!
asked Nov 2, 2023 by AndrewMeyer (20 points)
Hi, We would like to run an AD sync (Start-ADSyncSyncCycle -PolicyType Delta) after a new user is created. Unfortunately, it looks like this script only works for servers that ... in any of the domains. What is the recommended way to achieve this? Thanks, Max
asked Sep 7, 2023 by mcutlyp (40 points)
3,351 questions
545,079 users
