When a user is editing their information on the self service website, I need them to enter data into the extentionAttribute2 field. This needs to be a multi-line field so the user can enter carriage returns as part of the field. By default, this is displayed as a single line text field.
Is this possible to do in Adaxes?
Thanks in advance
by (200 points)
No, currently this can't be done, however instead of Extention Attribute 2 you can use one of the properties that support multiple values, for example, CustomAttributeTextMultiValue1. This is one of Adaxes virtual properties that can store multiple text values. Virtual properties are not stored in AD, but can be used the same as any other property of AD objects. You can use 1 value for each line of text.
I think you should introduce this thing, it would help us !
OK, thanks for the suggestion. We'll introduce something like this in one of the nearest releases, most probably Adaxes 2015.1.
I thought I would share this. We are new to Adaxes but really finding it a great tool to host some powershell scripts and make them accessible to others in the team without ... --------- If there are better ways to do this I am definitely interested.
asked Nov 29, 2018 by jbadry (430 points)
Hi team, hope you are doing well : ) I looking for a solution to edit multiple users and set attributes based on input. Let me explain: Helpdesk needs to select ... a text string and added to description or several custom attributes. Is this somehow possible?
asked Oct 16, 2023 by wintec01 (1.1k points)
Trying to set the primary proxy when doing a name change on an email address.
asked Jul 13, 2023 by mightycabal (1.0k points)
Trying to configure a custom launcher in Thycotic Secret Server that will launch Adaxes on the user's local machine with the username and password passed as parameters. Has anyone made this work?
asked May 20, 2022 by amillard (20 points)
When I try to provision a user for Enterprise Voice using the Line URI entry TEL:%telephoneNumber% or any other entry I get the an error. (below) When ... EnterpriseVoiceEnabled $True -LineUri "TEL:%telephoneNumber%" any ideas or help would be appreciated. Jim
asked Dec 12, 2013 by Tigger09 (140 points)
545,382 users
