When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties screen. For example, in the Organization tab, we would like to make a custom property available for users to be able to manage from there. We would also like to hide certain fields. This can be done in the web interface but I don't see the same option for the administration console.
by (80 points)
Unfortunately, there is no such possibility. However, thank you for the suggestion, we will consider it for future releases of Adaxes.
Can we increase the number of users shown under My Team?
asked Feb 24, 2020 by mark.it.admin (2.3k points)
for example i add a form "create user for France" in the left pane, how can i translate it automatically when the UI in in French ? thank you
asked Apr 29, 2021 by GG (70 points)
3,356 questions
7,799 comments
545,164 users
