Our security department has identify a vulnerability on our self service portal that allows cross-site request forgery and clickjacking due to allowing iframes openly. They have asked that we put in place a configuration of SAMEORIGIN or DENY using X-Frame-Options in our Web.config file. Is this ok to do or is there another suggested fix?
I also found this old article but our team was able to put the entire site in an iframe. https://www.adaxes.com/questions/889/adselfservice-security
by (2.3k points)
Helo Mark,
Have a look at the following help article: https://www.adaxes.com/help/?HowDoI.ConfigureWebUI.IframeEmbedding.html. On step 5, select No.
Thank you for that...is there any way to keep it on but add the configuration mentioned above?
Hello Mark,
asked Nov 30, 2022 by mightycabal (1.0k points)
asked Jan 19 by aweight (40 points)
Hi, we have replaced our local Exchange server with installation of Exchange Management Tools (EMT) installed directly on Adaxes server. And my question is: How can I force ... this is how 'Set External Senders' option looks in Adaxes config Thanks in advance
asked Apr 1, 2023 by KIT (910 points)
By default, SSL is not configured for the Adaxes Web Interface and network transmissions are not encrypted. However, you can configure SSL on the Adaxes Web ... work in both cases: with Windows-integrated authentication and with forms-based authentication.
asked Oct 14, 2010 by Adaxes (550 points)
3,362 questions
7,812 comments
545,227 users
