Dear Support, Is it possible in "generate default value" section of pattern for multivalued attribute to provide more than 1 value from "must be one of" section? E.g. Pattern for multivalued attibute is "must be one of: A,B,C,D,E" and to have default generated values in web interface "A,C"
Thanks for advise!
by (920 points)
by (3.6k points)
Hello Dmytro,
Unfortunately, there is no such possibility. However, the ability to set several predefined values for multi-valued properties on Web Interface forms will be added in the next major release.
Hello Dmytro,
The version of Adaxes that allows selecting several predefined values for multi-valued properties on Web Interface forms was released. You can download it here.
What’s New
Upgrade Instructions
We're utilizing the custom adaxes attributes for a few parts in our employee onboarding procedure. Among them is a step where we specify what buildings a user will need ... get all the values of "adm-CustomAttributeTextMultiValue1" to be sent out in an email?
asked Aug 9, 2021 by KruzGaffaney (50 points)
We are trying to enforce better consistency for user attribute values in a domain but without overly restricting user input when modifying/creating users. Is it possible to ... to these fields and create Custom Commands to change them which is very tedious.
asked Mar 21, 2019 by Staj (350 points)
We have a form to used by our HR Reps to create non-employee records. There are two fields on the form that are auto-generated via a property pattern: Full Name ( ... changed to cause this new behavior? Nothing has changed with our property pattern set-up...
asked Aug 30, 2016 by sandramnc (870 points)
Hello, I have trouble understanding the instruction listed here: https://www.adaxes.com/script-repositor ... s-s516.htm What should I put into $propertyForSearch and ... Since Adaxes is not the only system adding new locations to AD. Thank you.
asked Jul 4, 2019 by DLe (760 points)
Dear Support, is there a way to check not all attributes listed in the pattern, but only 1? For example user department not matching a list, provided in the pattern ... department and creating a separate pattern is really not an option). Thanks for any advise!
asked May 5, 2020 by Dmytro.Rudyi (920 points)
7,801 comments
545,173 users
