I want service desk to be able to select from the web interface only groups that are specified in a Business Unit. it is possible to do it (Adaxes 2009.1)?
Thanks you.
by (1.1k points)
Do we understand correctly that you have a Web Interface action when executing which you want users to be able to select only groups that are members of specific Business Unit? If so, unfortunately, there is no such possibility. As a solution, you can try using filtering options (e.g. LDAP filter) in the action settings to specify what groups should be allowed for selection. If you have issues with the configuration, please, specify the action in question and how groups to be displayed can be determined.
Also, please, specify what version of Adaxes you are using. Is it 2009.1?
Thanks for your answer. Yes, you understand well. We are using Adaxes 2019.1.
I did a scheduled task that add in a group all groups that are members of the Business Unit. Then, on my custom command parameters "param-groupname" I use an ldap filter (&(objectCategory=group)(memberOf=CN=groupwithBUgroups,cn=,....)).
It is now working,
Regards,
Hi, I'm trying to create a web console only for sending SMS using adaxes 2018.2. The SMS-users that are going to use the console should only be able to view users, not edit ... which removes a lot of OUs that the users should not see or be able to browse to.
asked Sep 2, 2020 by eirikza (120 points)
Hello, I have some AD Groups I would like to exclude from a business unit I'm using. I have standard group names across multiple OUs, some should be a part of the ... than simply having a working exclude query. Any thoughts on how I can get this working?
asked Mar 24, 2016 by drew.tittle (810 points)
we have created some business units which only return certain items in our directory. when using the web ui, how do we restrict browing functions to only look in the business ... unit. if this is not possible, how is it envisaged that these units are used?
asked Apr 14, 2023 by i*windows (260 points)
3,356 questions
7,799 comments
545,169 users
