We have tried to implement the Workday connector from Microsoft to start the inital user creation process once a new joiner has been entered into the HR Database but we have found problems.
We woud like to be able to provision joiners and leavers directly from Workday into Adaxes. I am not sure if Workday supports SPML or how I would identify this.
Are you aware of any Customers who have integreated workday with Adaxes?
Thankyou.
related to an answer for: Integration with HR
Unfortunately, we were not able to find any related information in Workday documentation. As another option, you can use PowerShell scripts to pass information into Adaxes. For details, have a look at our SDK: http://adaxes.com/sdk. We also recommend you to contact Workday support team for information on requests can be sent to Adaxes.
Unfortunately, we are not aware of such integrations.
I'm looking to audit file Share permissions, in order to find out what groups and individuals have access to what files and folders, whether those permissions are inherited or assigned, etc. Wondering if Adaxes can do this. Thanks in advance,
asked Mar 15, 2022 by sysdadmin (20 points)
Hi Everyone I want to create a custom command where I can select multiple users and then select a mailbox and give them full access to the mailbox. Is there a way to do it? Thank you for help
asked Nov 2, 2021 by Sandberg94 (340 points)
We are migrating away from on-premises AD toward cloud-only. Currently we are in a hybrid configuration with both on-premises AD and Azure AD. We are preparing to eliminate on-premise ... run Adaxes on a Azure vm server with only Azure AD an no on-premise AD.
asked Oct 6, 2023 by kevinleaverton (20 points)
3,365 questions
545,257 users
